Beryllium fatigue
Beryllium fatigue
Old 9th August 2018, 07:42 PM   #11
ScottG is offline ScottG  United States
-often the application of older drivers and newer cheaper drivers (and more expensive low-production numbers) is hand-done, and so less precise (aka SLOPPY).
It could also be an additional compound to dampen the outer-edge of the driver.
It really doesn't matter if it's Be or not, several compression drivers will have sloppy applications like this. Many compression driver maufacturers just coat the entire diaphragm and some give it a "special" proprietary name.
As for Be drivers - I don't think (guess) you would see cracking (without a good microscope) up until it actually failed. Sort of a "hard fail" material in this form and use. (..not unlike pure ceramic domes.)
perspective is everything
Beryllium fatigueHide this!Advertise here!
Less Fatigue from TangBand W4-1320SIF Destroyer OS Full Range 16 4th June 2017 06:23 PM
Class A Listening fatigue rcollege Solid State 13 18th December 2010 10:13 AM
Ear Fatigue ccdoggy Car Audio 6 26th February 2007 06:04 PM
which amp has had the least ear fatigue? JZatopa Everything Else 8 28th March 2005 03:30 AM
