Various loudspeaker design suggestions
Old 10th August 2018, 05:13 PM   #11
Lojzek is online now Lojzek  Croatia
Lojzek's Avatar
There is an alternative, a sealed design by Zaph called SB 12.3 that you may find on his website or as a kit at Madisound. This is a Qts =0.32 driver in a sealed enclosure with a low Fs to start with and in itself ideally suited to your taste.
A good dialogue makes you feel like a changed person, not like you have won or lost the competition.
Old 10th August 2018, 09:17 PM   #12
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
The Pensil is a simple rectangular ML-TL designed for one of the Mark Audio drivers — there are a range of sizes.
If one searches on “Pensil” in the forum search over 100 threads come up covering all sorts of questions and build threads.
There doesn’t seem to be a main Pnsil thread so i will link to the Gallery thread:
Pensil Pics, lets show 'em!
While the Pensils are for Mark Audio, there are some L’Stylo using the same alignment for Fostex FF105/125wk.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 10th August 2018, 10:52 PM   #13
jtgofish is offline jtgofish
I think you really need a driver with a Qts of of around 0.5 or higher for it to sound good in a sealed box.Yes you can use a driver with a lower Qts if it has a very low Fs like the SB Woofer in that design but I bet it sounds too lean and dry.Same goes for the SB 29NRX75-06 which I have tried in a sealed box and should work OK in theory [as recommended for the Kairos 3 Way] but does not sound good like that.
Old 11th August 2018, 09:15 AM   #14
00940 is offline 00940  Belgium
00940's Avatar
Another website with plenty of designs : Donhighend Audio It's in German but nothing a bit of google translate cannot fix.
I can also vouch for this place: Quint-Store As it is a kit store, the designs are not in the open obviously. The little µ-microspeaker is a killer desktop speaker.
All that is excessive is insignificant. Talleyrand
Various loudspeaker design suggestionsHide this!Advertise here!
Suggestions for a loudspeaker design codebreaker Multi-Way 9 16th January 2016 05:46 AM
How to design a loudspeaker TylerTraulich Construction Tips 34 25th November 2013 05:07 PM
Active Digital Loudspeaker Crossover - Part Suggestions solicitation speakerguy79 Digital Line Level 0 2nd December 2009 04:26 PM
Loudspeaker for open terrace -suggestions. swak Multi-Way 0 27th August 2007 05:40 PM
Loudspeaker Kit suggestions/help eastcoast Multi-Way 2 18th August 2005 08:22 PM
