Crossover advice
Crossover advice
Old 7th August 2018, 10:25 PM   #21
hubi is offline hubi  Poland
I really appreciate your help! thanks a lot!
I maked your scheme and another one that you suggest before.
Old 8th August 2018, 06:55 AM   #22
system7 is offline system7  United Kingdom
system7's Avatar
The results you got there were so bad, that I think there is something you are doing wrong here. The second one is not too bad, the first one is just a mess because you haven't adjusted it for your particular woofer.
I looked up the Eton 5", which is a fairly well behaved 6 ohm driver with highish inductance and a bit of natural rolloff.
https://lautsprechershop.de/pdf/eton..._880_25hex.pdf
The Morel tweeter is just a regular sort of 6 ohm thing and needs no special attention.
You said this is a custom design. Nothing wrong with it physically. I presume you have done something sensible with the bass loading. It's a reflex driver, QTs 0.4. Is it your filter?
You really shouldn't need anything beyond second order on the 5" bass and a crossover around 3kHz.
Since your modelling in vituixCAD is going so wrong, and I dislike that program as being unintuitive, maybe you should abandon it. Boxsim might give you a better time:
Software | Visaton
Boxsim Projektdatenbank
Import these bpj files for a quick start. Just find a similar project and import FRD and ZMA files.
Best Regards from Steve in Portsmouth, UK.
Old 8th August 2018, 08:28 AM   #23
kimmosto is offline kimmosto  Finland
I would abandon you from this site.
Old 8th August 2018, 08:55 AM   #24
system7's Avatar
You want to talk about speakers or me?
Your idea didn't look bad, but has been hopelessly badly implemented with that resistor on the bass, as you mentioned:
I'll leave you on first base to fix this mess. I'm out.
Old 8th August 2018, 09:02 AM   #25
thanks a lot !
I think I'm going to buy this drivers and put then in my case.
Old 8th August 2018, 09:06 AM   #26
^That's is version 1.1. I really hope that you study version 2, whole program package and it's philosophical targets before advising anybody to abandon it to something obviously worse. I realize that beginners are very difficult students because they may know close to nothing about acoustics, electricity and speaker drivers. This kind of discussions might still be quite entertaining.
Old 8th August 2018, 11:04 AM   #27
Zvu is offline Zvu  Serbia
Zvu's Avatar
I really don't understand why are you spinning the story. What's your stake in this ?
Kimmosto didn't recommend series resistor on the midwoofer. Quite the opposite, he tried to convince Hubi to get rid of it.
I'm starting to feel like i'm on some sort of crusade here because i've said it more than once, but i'll say it again - VituixCAD is the most complete loudspeaker designing software available for free. It is second to none regarding performance. No, it doesn't have an icon for every little thing one would imagine to do. None of the serious software does that. Feed it the right set of measurements and the resolution of what one is doing goes sky high. From 2010 i've used Passive Crossover Designer 7 by Jeff Bagby, WinPCD, Boxsim, LspCAD and recently VituixCAD. Transferring to VituixCAD from any of those is like going to Full HD TV from SDTV.
Not for fainthearted
Old 8th August 2018, 11:24 AM   #28
Listen guys thanks to everyone - all of you helped me!
I managed something from what I learned I maked it only from my hearing without any softwares and its sounds grate much better from the original crossover!
thanks again to everyone!
My next step will be buying a microphone frequency measurement
and start again.
Old 8th August 2018, 11:33 AM   #29
wintermute is offline wintermute  Australia
just another
wintermute's Avatar
Crossover advice
I have to agree with Zvu, vituixcad is by far the best speaker design software I've used so far. It doesn't do everything I want but it is damn close. The one thing that I go elsewhere for (speaker workshop) is putting multiple curves onto one graph so that I can compare them.
I didn't like the crossover modeling in version 1.1 but lucky for me version 2 came out within a week of me trying version one and I like it a lot!
I've used PCD7, boxsim, xsim, and speakerworkshop and I think Vituixcad 2 was by far the quickest to get up to speed on.
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 9th August 2018, 10:28 AM   #30
Simulation with traced SPL and Z curves and simulated box, LF impedance and directivity. This method is possible with VCAD but it's as difficult as with proper measurements. Looks nice but reliability with traced responses and simplified simulations might be low without luck. Not for manufacturing.
Crossover adviceHide this!Advertise here!
need advice on crossover phatkev Multi-Way 5 8th November 2017 05:41 AM
Crossover Inductor DCR Values and General Crossover Advice Wayniac Multi-Way 6 15th December 2012 02:59 AM
crossover advice mart43 Multi-Way 6 5th August 2012 07:35 PM
Crossover advice hollowtek Car Audio 1 17th October 2009 11:54 PM
crossover advice please REALFLEO Multi-Way 6 18th December 2006 11:53 AM
