Open source speaker project?
View Poll Results: choose your way!
3 way classic - limited (Under ~500$ Drivers and Parts). 39 20.97%
3 way classic - High end (Above ~500$ Drivers and Parts). 43 23.12%
3 way horn loaded - limited (Under ~500$). 8 4.30%
3 way horn loaded - High end (Above ~500$). 24 12.90%
2 way classic - limited (Under ~500$). 20 10.75%
2 way classic - High end (Above ~500$). 14 7.53%
2 way horn loaded - limited (Under ~500$). 25 13.44%
2 way horn loaded - High end (Above ~500$). 13 6.99%
Voters: 186. You may not vote on this poll
Old Yesterday, 08:00 PM   #231
mbrennwa is offline mbrennwa  Switzerland
mbrennwa's Avatar
Originally Posted by mordikai View Post
tweeter- Wavcor TW030WA12
mid- B&C 8MDN51
Why did you suggest these? An 8 inch driver seems a bit odd as a midrange driver in a home/hifi loudspeaker. Also, its 97 dB sensitivity seems like a big waste compared to the 91 dB tweeter.
[ audioroot.net | hifibau.ch ]
Old Today, 01:28 AM   #232
mordikai is online now mordikai  United States
Send a message via Yahoo to mordikai
I don't disagree. I would like a tweeter I can cross low and has decent directivity match to the large mid. Do you have recommendation?
I chose the 8" mid because I have heard it and really like the way it sounds. I could try one of the 6" B&C mids which should match directivity with the tweeter better.
I figure with wide baffle and low placement I should have minimal baffle step losses on the woofer, so probably 92-94db.
Old Today, 02:21 AM   #233
mashaffer is offline mashaffer  United States
Or go with a tweeter with a bit more hair on its chest
File Type: pdf 294-580-bc-speakers-de35-specifications-45777.pdf (129.4 KB, 7 views)
The only reason I drive the 91 Colony Park is that I can't afford a 65. Me old school? Couldn't be.
Open source speaker project?Hide this!Advertise here!
NE Wisconsin diyAudio members...Do you like FREE speakers? NFLMVP Swap Meet 13 21st September 2011 03:13 AM
diyaudio moderator vs diyaudio member Leolabs Everything Else 6 18th June 2006 08:19 AM
A diyaudio DCX2496 purchase for prototyping new speakers akunec Digital Line Level 2 18th August 2005 12:30 PM
