Conical speakers - Page 2 - diyAudio
Old 25th April 2002, 10:53 AM   #11
Default ...volume
...And the speakers volume will be about 9 liters before I have put any of the elements and circuiting in it.
Old 25th April 2002, 12:25 PM   #12
Andy G is offline Andy G  Australia
Andy G's Avatar
Default more vent length....
My calculations in WINISD and BB6 seem to indicate that what you have at the moment will give you a bass peak in the 60-75 region, not good !! Have you used WIN ISD at all? Its a free download from http://www.linearteam.dk/winisd.html and has your driver in its database. Its pretty easy to use and generally gives pretty good results for bass alignment.
It seems to indicate lengthening the vent to about 180mm. If this is too long, try reducing the radius.
Old 29th April 2002, 04:48 PM   #13
Default ...bass peak
I don't think I can get the speakers much lower than 65 Hz which according to my calculations is what I will get. I am likely to get a muddy sound...
As for the project it's coming along nicely. I'm going to make holes for the elements tomorrow...
The element will end up sitting quite close together, a bit less than 2 in (4,5 cm) apart....
Conical Horn with Markaudio Alpair10 FR Henkjan Full Range 34 4th April 2011 03:26 AM
80 hz 15' conical midbass horns winslow Swap Meet 1 7th August 2010 12:16 AM
Midbass Conical Horn - Keele vs Hornsresp which is the better FR? steve71 Multi-Way 28 27th October 2008 07:35 PM
Compensation for Conical Horn Sheldon Multi-Way 1 11th November 2006 10:01 PM
Conical spring washers ?? sam9 Parts 11 24th June 2004 09:17 PM
Copyright 1999-2017 diyAudio
