Building plans for Dayton portable speaker
Old 17th July 2018, 11:48 AM   #1
Hallislaok is offline Hallislaok  Norway
Default Building plans for Dayton portable speaker
Was making some plans for my speaker building project, which will be a bluetooth portable speaker, with parts from parts mostly from Dayton Audio. Is kind of new to this whole thing so was wondering if i could get some feedback on the parts i have chosen etc. so i can make some improvements on the plan before i get started.
amplifier: Dayton Audio KAB-250v3 2x50W Class D
Dayton Audio KAB-250v3 2x50W Class D Audio Amplifier Board with Bluetooth 4.0
woofers: 2 x Dayton Audio ND140-8 5-1/4"
Dayton Audio ND140-8 5-1/4" Aluminum Cone Midbass Neo Driver 8 Ohm
tweeters: 2 x Dayton Audio ND25FA-4 1"
Dayton Audio ND25FA-4 1" Soft Dome Neodymium Tweeter
The enclosure will be wood with a suitcase like shape, and each woofer will have separate chambers that will be 10-12L of space when the sound dampening material and the electronics is in place. Each chamber will be ported with a 2" port that will be around 8 inches long.
Wanted to make my own Crossovers so used VitiuxCAD to create a schematic which gave me this frequency response graph. The crossover is set to at around 3000hz.
The board has two 50w channels so the tweeter and the woofer goes in parallel for both channels. This will make crossover work a lot easier as well.
For the batteries i was thinking about using the 3 or 4 of the Dayton Audio KAB-BE 18650 Battery Extension Board. (Dayton Audio KAB-BE 18650 Battery Extension Board for Bluetooth Amplifier Boards). With 3 3000mah batteries on each board gives the system approximately 27000-36000 mah at 12V.
Thanks in advance for feedback, and if people are interested I can post updates with pictures from the build as I go.
Old 17th July 2018, 11:54 AM   #2
Pano is offline Pano  United States
Pano's Avatar
The KAB 250 amp works well. I use them frequently.
Looks like you are on the right road with the crossover. I'm sure you'll get more detailed responses as people see this.
Take the Speaker Voltage Test!
Old 18th July 2018, 11:57 AM   #3
Yeah that would be great!
Old 18th July 2018, 07:37 PM   #4
Lojzek is offline Lojzek  Croatia
Lojzek's Avatar
I reckon that you have not included baffle step response into the simulator, yet. Perhaps you should upload the boombox drawing and designate where you'd like the drivers installed. An 84 dB driver on paper, once in free space loses good 4-5 dB, so right now you filter has room for improvements.
A good dialogue makes you feel like a changed person, not like you have won or lost the competition.
Old 19th July 2018, 12:53 AM   #5
Here is the original design i was thinking about, its 60cm x 20cm x 30 cm. Thinking it might be better off being 40 cm tall instead though because with 30 cm it might be little room between the port and the back side of the woofer. And i need to fit the electronics in the back as well, and 40 cm will make it more spacious.
Old 19th July 2018, 03:11 PM   #6
Have another design I just made thats a little bigger, and its 2 ports per chamber instead of 1 port and moved the ports to the front to reduce the velocity of the air, and the length requirement to get the tuning frequency i want of 54hz. The box measurements are now 50cm x 30cm x 40cm.
Old 19th July 2018, 04:38 PM   #7
Lojzek's Avatar
May you will give it a shot and try something along these lines. I assumed the baffle as 60x40 cm.
Old 20th July 2018, 12:24 AM   #8
Wow can't get XSim to work properly, but that graph looks pretty damn nice. Yeah the baffle will be 50cm wide and 40 cm tall. I can do the exact same thing for both left and right channel right? That equates to around 50L inside of the box, actually gives around 15-20 L per chamber after electronics and dampening material. Any thoughts on dampening material btw?
Thanks for the help so far
Old 20th July 2018, 03:42 PM   #9
Lojzek's Avatar
Sure, once you find a satisfactory filter, then it's the same for both of the speakers. Damping material was never critical. Whatever suits the purpose. Some line the cabinets, some stuff, some mix both of these. I stuff the enclosures to a degree that I am certain all standing waves will be suppressed and leave some space for free vent air flow.
Old 24th July 2018, 12:45 PM   #10
Was thinking about lining it, because idk if the stuffing will absorb moisture if i bring it outside. Here is how my XSim graph turned out:
Used the FRD and ZMA Files from Parts Express, the ones at 0 degrees. How did you calculate baffle step into the frequency response curve? And is the baffle step the only reason our graphs look kinda different?
Building plans for Dayton portable speakerHide this!Advertise here!
Building a blue tooth fullrange portable speaker? Jeffrey 01 Full Range 10 22nd September 2016 09:43 AM
Building my first portable and rechargeable speaker roquestar Multi-Way 7 4th August 2015 07:36 PM
Building a rechargeable and portable speaker The Jesus Multi-Way 11 26th October 2013 04:39 PM
Building a portable speaker system...from scratch. Zlash03 Construction Tips 16 3rd February 2013 02:51 AM
Building my own portable speaker system... HELP!!! audiomansteve Multi-Way 2 22nd April 2008 04:26 PM
