Which power amplification for different powered speakers ?
Old 12th July 2018, 10:52 PM   #21
Galu is offline Galu  Scotland
Class D is more efficient than class AB.
However, to get 100W from a 25V supply needs a minimum current capability of 4A no matter which class you choose.
Watts = Volts x Amps (W = V x A) is the calculation you need.
Old 12th July 2018, 11:00 PM   #22
To put it simply:
Batteries like yours are not suitable for powering high wattage amplifiers.
It's not a matter of battery life, it's a matter of battery capability!
Old 12th July 2018, 11:18 PM   #23
TanguyClt is offline TanguyClt  France
Yes I understood that I have to get 24V. I think I will keep the 50W amp but supply it better because if I take a powerfull one I will not be able to make/buy a sufficient battery. If I make 2 pack in parallele of 6x18650 in series, then the current will be 1A instead of 2A for each pack. Is that doable ? Indeed I only have lithium battery so I try to make with that^^.
Old 13th July 2018, 11:34 AM   #24
That is a very good decision!
Go ahead with your idea of putting two blocks of 6 series cells in parallel.
Please let me know if that combination solves your problem.
P.S. If you have a multimeter, you could monitor the battery voltage to find out how much it falls as you increase the volume of the amplifier.
If the voltage falls a lot then you need a supply with more current capability.
Old 13th July 2018, 11:48 AM   #25
Ok I will thanks, but it will not be now because I'm busy
Which power amplification for different powered speakers ?Hide this!Advertise here!
Are there any low-power class D amplifiers that are not crap for guitar amplification mnesarco Instruments and Amps 29 24th March 2017 08:38 PM
What type of speakers for my passive amplification setup lukesmith123 Parts 7 11th June 2013 12:28 PM
Qtx powered speakers... amptech Solid State 1 1st October 2012 12:55 PM
power amplifier with one-stage voltage amplification alex0 Solid State 5 7th February 2004 12:02 PM
