SPL trace question
SPL trace question
Old 11th July 2018, 10:47 AM   #1
nigelb63 is offline nigelb63
Default SPL trace question
I am trying to generate an FRD using spl trace. looking at the image the trace is cut off at the lower of the scale. What would be the best approach to achieve a workable trace?
Old 11th July 2018, 11:13 AM   #2
TBTL is offline TBTL  Germany
It does not matter too much because it is already down by 20 dB and it is likely to be even further suppressed by an electrical low pass filter. I would trace the lower scale limit or an estimate of the curve.
By the way, there appear to be more versions of this Volt BM220 woofer with for example a significant difference around the 2 kHz peak:
https://voltloudspeakers.co.uk/wp-co...03/BM220.1.pdf
https://voltloudspeakers.co.uk/wp-co...12/BM220.8.pdf
Old 11th July 2018, 11:29 AM   #3
AllenB is offline AllenB  Australia
I would also guess the dip. However, I wouldn't be trusting a single measurement in this chaotic region, I would be cutting it to be sure.
Old 11th July 2018, 12:40 PM   #4
Thanks for your response. I have contacted Volt to clarify this difference. As I understand it, the BM220.8 and the BM228.8 are the same but the part number designation is all that has changed.
SPL trace questionHide this!Advertise here!
Trace repair S Merlington Car Audio 2 21st October 2015 01:30 PM
help with spl trace mcmahon48 Multi-Way 2 21st April 2009 11:16 PM
spl trace testarossa2k Multi-Way 3 8th November 2007 11:10 PM
ES-JLH bis: Trace Elvee Solid State 0 27th September 2006 04:42 PM
non os for cdp without pcb trace cutting Bernhard Digital Source 16 20th April 2004 03:58 PM
