Hello,
I was thinking about dropping 4k on a pair of A.D.A.M. studio monitors when i realized that they are just the eton woofers and a ribbon tweeter (which looks to be propriatary to ADAM??) and that the amps are probably not as nice as the bryston 4b st that I have sitting here. Then I realized that there are all these great digital XO's that would make testing and tweeking very easy (similer to the DEQX). The other thing that I realized is that most studio monitors lack puch- because they are 2-way designs they use low xmax mid woofers for accurate mids and therefore sacrifice that in your face kick that many HiFi systems have. Also my dad is an expert woodworker who has built many speaker cabs before so I came to the conclusion that I would be able to do better- especially considering that I don't have to tweak the XO by adding components and I only need to get a good amp for the HF drivers. And I could do it cheaper! or way better and the same price. . .
So on that basis I decided to start looking at ribbon tweeters and I found the Aurum Cantus drivers from e-speakers. They look pretty flat, shielded (this is important to me), and they feature a low xo point and they have inexpensive replacement diaphrams- wich is also important to me (as the occasional feedback or somthing is very likley to damage the tweeters sooner or later). I like ribbons because of there near perfect frequency, phase and impulse response- is there anything I should know about them?? (other than the fact that they are relatively fragile)
So I think I am pretty set on the AC G1 tweeter. I will get a behringer 2496 DSP based XO that has up to 48 dB/oct slopes- I am wondering if people who run active setups with ribbon tweeters find it necessary to install a passive HP filter to protect the tweeter??? My main concerns that I can't seem to find in the specs are distortion and thus listening fatuige- Listening to speakers is not my hobby- it is my profession. And I need somthing that I can listen to (at reasonable levels) for 40+ hours a week without my ears burning up. -my current NHT A 20's are great sounding and good to mix on but horrible in this department. The bass from them does not really kick in until the metal dome tweeters are loud enough to really wear you out after a 8 hour session.
Also the XO has 2 notch filters available per band and each is selectible between 6 dB/Oct and 12dB/Oct. Does anyone here have any experience with this device? It is base on Shark DSP's and provides auto-time allingment for all internal functions (as well as manual time allignment if it is needed to increase full range phase accuracy). I do plan on using a test microphone to tune the system.
So with all that in mind the kind folks at e-speakers.com told me I should be able to push the XO point all the way down to 1k (using the 48dB/oct Hp filter) for the AC G1. The only thing that I can find that is better than that is the manger (wich has some other drawbacks that i don't like too much) and the raven r3 (a pair of those exhausts 90% of my budget and is no longer available anyway). This system will be active of course (so i still have to buy a good amp for the tweeters).
This seems to be good because now I can use a high excursion woofer that might exibit alot of cone breakup before it would mate well with a normal tweeter with a higher (2-3k) XO point. this wil give me more punch right?
So now the question is 2-way or 3-way??? I have a sub, and of course if this goes well the DIY sub is next. But I do want to be able to achieve an F6 of 40-50hz in my monitors. And I prefer sealed boxes so I will need a driver that can actually do this.
So I went on the hunt for high excursion woofers that seem to be able to play up to about 1k and don't exibit major cone breakup until an octive or more above that. which lead me to the aura ns12, wich has a 2 inch peak to peak excursion and it appears to have a high enought QTS to function well in a sealed cabinet (.43). Am I on the right track here?? does anyone have any experience with this driver??
I emailed Aura and madisound and the company said that it exibits cone breakup at 2k and they recomend an XO freq of 500hz or lower- madisound suggested a freq of 150hz but they said the engineer thought this would be the case due to the 4" voice coil. It seemed to me that this was the suggestion based on specs not necessaryly real world conditions. Neither of the two replied to as to weather or not I could push the XO point all the way up to 1k if I used a 48dB/oct XO. The aura does not exibit cone breakup until about 2k- I would be able to be 48 dB down at 2k and I could use one 12dB/oct notch filter at 2k (so 60dB down at 2k)- But i still have a hard time imagining (in my little world of mental physics) a driver having good control of minute 1k motions while simultainiously traviling 2 inches back and forth. E.G. how well will this driver produce a sine wave bass- a kick drum and the fundamental frequencies (and some first overtones) of a human voice simultainiously??
My understanding is that the larger the voice coil- the more directional the higher frequency information becomes- is this a good rule?? So generally speaking I should not use a driver like that up to 1k unless I plan on sitting in a small sweet spot only??
The other driver that appealed to me was the peerless 10" CSX driver. This one has a smaller VC and a lower linear excursion of 9mm one way (which is still much better than the 3mm vifa's that are in my NHT monitors - or the 4mm of the eton's). The other comparable driver is the FOCAL 11K7512 or the FOCAL 13W8711, wich both have 9mm one way excursion as well. It seems to me that any of these would be a better choice for a 2-way system with the Aurum Cantus. Both of the focals have a qts of about .35 so is that too low for a sealed inclosure??? Again I am not looking for Subwoofer performace in terms of sine waves but I do want that puch and an F3 of about 40-50hz.
So I guess my main question here is- can I get away with a 2-way design?? I know that all these drivers are tested with a sweeping sinewave- what does that mean about their actual performance in terms of music or even pink noise matierial?? I would rather go 3-way if that is what I have to do to attain really good midrange response with actual music. If I went to a three way design I would probably be thinking about a smaller Tweeter with a higher XO point - say a hivi or a ac g2 or G3 and a mid that would bridge the gap between there and probably the Aura ns12- as it seems to be the ultimate expression of punchy low end (at least in terms of specs).
The reasons I would prefer to go 2-way are;
the cost- (3 way means 6 drivers and 3 stereo amps)
and It seems to be difficult to find high- max spl midrange drivers. . .
Oh yea I forgot about this- I am looking for a system that easily hadle peaks in excess of 125dB at 6 feet. And that can handle average levels of 110-115 dB rms. the main thing with the peaks thing is that I am dealing with music that has not yet been compressed (dynamically speaking)- This means huge peaks over average as compared to music that is already compressed in the mixing and mastering stages.
So the Ribbon should be fine here as it is extreemly sensitive and offeres considerable power handleing. So what mid-range drivers are available that can - single handedly (e.g. without needing 2 or more per speaker)- cover the range and the amount of spl that i am looking for?? I noticed the Davis 8" mid or maybe a soft dome mid??
Can mid range drivers be pushed a little further (in terms of max peak and rms spl) when they are HP filtered??
Anyway I am just looking for ideas and I am looking to fill in the gaps in terms of the knowledge that you guys have, from doing it before (I have actually built speakers before but they were passive speakers for playing live - I play piano). Any answers to my rediculous stream of conscience questions or advice or thoughts about other drivers would be greatly appriciated. Thanks,
Ryan
Ryan
Whew... my short term memory is to poor any more to remember all that! 😀 I'll just give ya my 2 cents on a couple things. Ribbon seems a good idea for studio monitor because in addition to their good response they have generally good directivity in the vertical axis (minimizing ceiling & floor/table reflections). For studio monitoring you want to minimize room coloration. On the 2 way vs. 3 way... definitely 3 way. This can be either 2 full 3 way speakers or 2 x 2 way satellites crossed to a single sub. I prefer the later. 2 way satellite with woofer from 100 Hz to 1-3 KHz (wherever you choose for your ribbon x over point) would be nice. One beauty of choosing 100 Hz as your target for xover point to sub is it also then matches up nicely to a 5.1 surround setup in case you want to do any surround mixing. I wouldn't think of doing a 2 way with woofer going all the way from 40 Hz to 1+ KHz.... to much Doppler distortion of mids & highs riding on the long excursion of freq that low.
Thanks,
I was actually debateing between a 3 way with a sub or a 2 way with a sub. So ulitimatly I'm looking at 3 way or 4 way. It sounds like from what you are saying that if i want quality mids and high excursion woofers that I should go 3 way on the monitors (and 4 way total). The main thing here is not to try to get much of anything over 150hz from a high excursion driver right??
what about this
Aurum Cantus G1
PHL mid or focal audiom 6wm or ??????
Aura ns 12 or peerless xls 12 for the lows
The main thing I need in my design is a mid that has high max spl
The reason I am wanting to go this way is that I want my monitors to have much better bass response that what I have now- I have NHT pro a-20's which reach down to about 80 but are lacking considerably around 100-150. The layout of my studio also works better with a sub that is not responsible for punch frequencies- only the thudy stuff say 50 and below. According to the calculations in winisd the aura will go down to about 45 so that is what I am looking for- BTW there are no surfaces here that boost the bass significantly (eg floor or wall or corner) So I need the speakers to do it on there own.
Also if anybody has any driver recomendations- especially for a high max spl mid I would love to hear them.
Also it has been a while since I did this last and I seem to remeber that a driver has an increased sensitivity and max spl when it is put into a cabinet- Is this only below 150hz? and how much additional dB?? thanks again,
Ryan
what about this
Aurum Cantus G1
Ryan
Im sure you have already thought about this but I thought that I would throw it out anyway. Studio monitors are made to be reference tools, not necessarily the best sounding speaker. If for instance the speaker augments the mids over other frequencies and sounds good because of it it will be a poor monitor because it isn't telling you exactly what your mix is doing. In fact in this scenario you will most likely produce mixes that are light on the mids. Sometimes monitors don't sound all that "musical" but that isn't their job.
The Event Studio Precision 8's are really great monitors with a really flat response, there are also powered versions which are even more predictable.
Milo
On the other hand the speaker it sounds like you would build would sure have some killer stuff in it, so it would be damn fun.
Milo
Ryan, how about 8" or even 10" aluminium cone speakers from Seas, Visaton or Alcone? (I think the Alcone ones are shielded btw). Maybe pick one out that suits your intentions for box size and highest sensitivity.
There is a problem with using steep filters: ringing, and that is one major thing that causes listening fatigue. It will be practically impossible to sum together 2 steep filters to cancel out that ringing. If it's cancelled out on-axis, then it will be even worse off-axis and vice versa. A Bessel filter is has the maximum possible gradient-delta (sharpness) that doesn't cause any ringing. But, since the filter is not sharp at all (regardless of its order) it requires speakers with a wide frequency overlap. An even wider overlap is needed for Linkwitz-Riley filters.
Even if a speaker has a completely horizontal frequency response, it may still be quite rough as if it has a whole lot of steep bandpass, notch, and comb filtering done to it. Such filtering is mechanical and is caused by several things: internal box resonances that push against the cone, horn-loading, and cone break-up.
If you are sensitive to listening fatigue (as I am), then any soft cone material like paper, fabric, or polypropylene just won't cut it. Many of the so-called "high sensitivity" speakers only get good sensitivity measurements because of their resonant peaks from cone break-ups at relatively low frequencies in the midrange. Sometimes the frequency response graphs aren't even provided (PHL anyone?
), or they are smoothed out to hide the most important information. On the other hand, a speaker with a hard cone (like aluminium) will have worse cone break-ups, but at frequencies that are high enough to be filtered out, like 5kHz.
To reduce the effect of internal box resonances, you will need a speaker with a low Qes, and definitely keep to your decision not to use passive crossovers. You may be able to boost the low-frequency sensitivity with a band-pass step filter if you use a sealed box. For this you will need a high-powered amp with high voltage rails that can take advantage of the impedance peak of the woofer.
CM
CM
If you want high SPL & low distortion (fatigue) - I can see two choices;
A 3 way or a 2 way MTM with a sub.
Now the sub drivers you've picked are just that for sub - I wouldnt go any higher than 60hz with them, so you really need another bass driver, to help with that 'punch range' 100-200hz.
A pair of Eton 7" in an MTM with the AC ribbon would be really nice & relativley simple. An MTM would help minimise floor/ceiling reflections & give you a nice symmetrical repsonse through xover (provided x-point is kept low enough).
My pick would be the Eton 2 x Eton 7-372 in a vented box (vented boxes achiev higher SPL with lower excursion requirements).
If you want to go the 3way route it is considerably more complex & expensive.
PHL / Focal / Eton are all good choices.
yea, its possible:
http://www.pioneerelectronics.com/pna/product/detail/0,,2076_4219_35957,00.html
i think my systems comes near to your specs http://www.diyaudio.com/forums/showthread.php?s=&threadid=7032&perpage=15&pagenumber=1
Cool,
Thanks for all the good Ideas-
I have a couple of questions-
Can a mid-bass driver achieve higher max spl if it is hp filtered? Say 12dB per octive at 100hz
Also Will the ringing in the steep slopes be an issue with an active dsp based XO? I was hoping it might allow me to cheat a little but maybe not-
To A3rd.Zero
i understand this- that is why I am planning on tuning the system to my room- The XO that I will use is DSP based and has 2 parametric filters per band (boost or cut) in either 6dB/OCt or 12dB oct- It should allow me to obtain a much higher degree of accuracy than any off the shelf system like the events (my passive 20/20's measue in at + or - 15dB in my room!!).
to Ap-
do you really think the aura ns 12 would need to be LP filtered that low?? Why? madisound told me 150 and a rep from aura said 500. I would not want to go that high as I understand that IM goes way up in the HF of a high excursion woofer but I figured I could go at least to 100 or 150 at the highest.
Anyway I think i should be able to obtian sufficient overlap here if I can find a Mid or mid bass woofer that can go from say 100hz to 2k and can produce jthe max spl's in the range that I am looking for.
That is why I am wondering if I were to actually HPF a mid bass driver at 100hz would I be able to squeeze more max spl out of it?
The other thing that I am interested in is amplifier recomendations- I have a bryston 4b st that I can use and I was thinking about one of the studio hafler amps for the tweeter (100 wpc althought I doubt if it will need 1/3 of that). And then maybe find somthing for the mid depending on which one I get.
As you can tell I am leaning more toward the 3-way TMW design, I like the MTM idea but I only need control of downward HF directivity- up is fine (my cieling is acoustically treated), Plus I would like to use the bryston and get the most out of it so it makes sense to me to use it for the woofers. An MTM, in my active design, would probably still be a 3 way (unless it was push-pull right?) . It is my understanding that it is better to have one M run up to the tweeter and the other only up to about 150hz or so?? At wich point it seems to me like- Why not just get a really kicken woofer and a quality mid- each driver being the ultimate (or almost atleast) expression of it's dedicated frequency range.
Again any input here is helpful- thanks again,
Ryan
To A3rd.Zero
to Ap-
Ryan
I dont discount the Aura 12 can go higher , what I was alluding to was room placement & blending with the mains. I find it much easier & sonically better when the sub is kept below 60hz, different story if you are using it for a bass driver in a 3way.
I do like MTMs for simplicity & efficiency, as for mixing & matching amplifiers I have never really had good results doing this - although in a studio setup things are different.
And yes you will achieve higher spl by having a HP on your midbass as it will reduce its need for xmax - does that makes sense? In other words excursion increases greatly below 100hz.
PS check out the Dynaudio m2 - large dome mid & a pair of 8" in a 3way - that would work!
http://www.dynaudioacoustics.com/Default.asp?Id=282&AjrNws=141&AjrNwsPg=1
Ryan, can you tell us a bit more about the speakers you currently have? And whether the 110dB-115dB sustained volume is the speaker sensitivity, or in-room loudness?
CM
CM
PHL 15''
You can use a PHL 15'' up to 1.6 KHz no problem. I have done it.
You can have 2way and sensitivity and spl and power handling.
Reminding you the Nexo PS15 which uses the 5320 but I would opt for the lower sensitivity lower fs and better sounding variant that you can see in their site www.phlaudio.com
Allright-
Let's see-
CeramicMan- My current speakers-
http://www.nhtpro.com/2004/products/product_detail.asp?ProductLineID=1&ProductID=3
I can't say that I know excatly what absolute values I am looking for in terms of max spl. What I know is that I wan't them to be able to be cleaner and considerably louder than my current system. And ultimately I am talking about in-room loudness- This is a 850SF room with heavy acoustic treatment (6" of rock wool insulation on all walls, acoustic foam on the cieling now but soon to be 3" of rock wool also).
AP- the M2 is kinda what I am going for- or really it would be more like the air25 because I am going for the tunable active type setup- I guess the title of the post really should have been studio mains-
http://www.dynaudioacoustics.com/Default.asp?Id=2846
The only major difference is that The AC G1 tweeter can be crossed over much lower than the fabric dome they use-
So what about this-
Aurum Cantus G1 tweeter
XO- (somewhere between 1k and 3k depending on the slope steepness and what sounds best etc)
SCAN SPEAK 15S/8530K-01 5-1/2" REVELATOR SHIELDED MID/WOOFER
XO- somwhere between 100-200 depending on the revalators max spl/distortion/xmax factors come to play
Aura- ns 12
One qustion about the the max spl of a HP filtered mid bass-
How can I calculate a rough max spl- each octive lower requires 2 x the wattage to equel the same amplitude right??
So if the revelators (roughly speaking here) can handle 60w to produce 100dB @ 30 hz- then 60w can produce 106 dB at 120hz?? or 109 dB at 240hz??
Salas- I am still leaning away from a 2 way like that, a 15" driver becomes very directional at 1.6k right?? I generally fell like somthing like the revalator would give me tighter better mids (from 120- 2k or so) than a big old 15" driver.
Also one thing with the crossover that I forgot to mention is that I am not tied to any specific XO frequencies-
What I mean is that the sub drivers could be LP filtered at 120 hz at 12dB/Oct and the mid bass drivers could be HPF'd at 100HZ at 18/dB/OCt and LPF'd at 1.5k at 48 dB/oct- All filters are selectable between LW and butterworth and the xo will provide automatic delay compensation for each driver- meaning that a driver with only a 12dB/Oct filter will be auto time alligned with a driver with a 48dB/oct filter-
Here is a link to that:
http://www.behringer.com/DCX2496/index.cfm?lang=ENG
BTW: I would never use it's built in SRC- if I am recording at 44.1 or 48k I will just go analog out and in- If I am recording at 96k Then I will go direct via AES/EBU- But the 96k opteration is good because it lowers the latiency of Hi Q filters-and increases thier overall quality and accuracy- especially in the higher octives. Plus it has a nifty little program for the computer that allows you to easily set all of it's settings - and save presets. This might even be a great tool for you passive guys to test different XO setups without haveing to change components.
thanks again,
Ryan
Let's see-
So what about this-
Aura- ns 12
thanks again,
Ryan
Oh I forgot to mention the rest of my current system-
I have a pair of paradigm monitor 9's that are decent (ppwered by the bryston 4b-st) They have a similer charicter to the NHT's tonally speaking but are a bit easier on the ears-
I also have a polk sub with 2 -12's it is really more of a novelty than anything else, I can turn them all on and off from my listening position- It provides a big 60hz but not a whole lot beneath that. It does help just to ensure that there is no massive speaker damaging bass that the NHT's would not really tell me about, and all the rappers love it!!
As for now the system I am thinking about building would replace the paradigms in my layout- for now i will keep my NHT's because I am used to them (and so are my clients)- No matter what I will always have some type of smaller nearfield and larger mid/far field (although they are probably both in the nearfield from my sweet spot). If this goes well then the smaller nearfields are next- thanks again,
Ryan
Ryan
15'' etc
The PHL 15'' does not sound closed in up to 1.6K. Also the Nexo PS15 which is THE wedge monitor for vocals delivers just that...good mids among other things.
Better use an 8-10 inch PHL (they have a fantastic sounding 8'' & a 10'' one) down to 100Hz and cross to an active sub. Dont take the AC1 near 1K you dont like voices to come out from a ribbon from so low. Trust me on that. Another thing to remember is when you cross from a wide polar to a line source, the difference is too apparent. I would take the 8 inch up to 2.5K.
At a glance, sounds like you need to find a used pair of Urei 815Bs: http://www.jblproservice.com/pdf/Vintage JBL-UREI Electronics/UREI-815B.pdf
GM
GM
Cool,
So GM:
I've never used the 815b but I have used 811b's and 813b's- There a little too vintage sounding for my taste- I know that might seem offinsive, but I don't mean it to be. I just have ears for tighter puchier speakers. When I used the urei's in the past i spent most of my time listening to the small nearfields (genelecs).
That's why i'm shooting for more of a mid field monitor type design. Not PA speakers for your studio and not little no real bass monitors (I already have those!!)
Also they are HUGE!! and they really deserved to be soffit mounted- Which is as big of a DIY project (if not bigger) than building the speakers myself.
I'm going more for somthing like this-
http://www.adam-audio.com/studio/mainfield/s5va_data.htm
However I don't fell the need to use only eton drivers (and the tweeter looks like the ER-4 but that mid ribbon is still unavailable). I think Eton, LPG and ADAM are the same company no?
Plus my take is this all those $5000 a piece speakers have amps that are not the equvolent of my bryston- and there are better amps than it (no doubt) so a modualar system gives me infinit upgradeability.
Salas;
Is it your opinion that the phl 8" is the best driver for 100hz to 2.5khz? Is there a sheilded version available?
Also do you think I should get a cheaper tweeter (like maybe the aurum cantus g2 or fountek jp-3) if I am going to x it over that high anyway? Or would it be better to have the G1 and use softer slopes?
Also are there any takers on rather or not steep slopes will have ringing problems on a dsp based XO? Can anybody tell my why steep slopes cause ringing?
And one more- Is there any DIY shielding solution available?? This would greatly increase the amount of drivers that would work in my configuration.
So GM:
Salas;
I may have been way off the mark earlier about my reasoning for your ears fatiguing. I think it may be much simpler than things like ringing, and the more subtle ringing from sharp crossover filters. It may be that the tonal balance changes at high volume towards a much brighter treble, due to the midwoofer not coping and distorting a lot.
Sonic compression of bass frequencies just from the heat buildup will make hardly any difference, but if the woofer's cone is moving several millimetres, it may be compressing the bass mechanically, and thereby producing a lot more midrange and upper midrange energy. If the amp is clipping, then the situation will be even worse.
Despite my ideologies, I think an MTM, or MTMM design could be a very good solution in this case. Multiple midwoofers (of moderate efficiency but very smooth sound) such as aluminium 6.5" Seas/Visaton/Alcone ones in some series-parallel combination will probably sound much smoother than a PA-style high efficiency single woofer. Furthermore, if you research things about "baffle step" compensation and things like that, you will also find that 2 woofers in close proximity will be up to 3dB more efficient in the bass, on top of a 3dB increase from a doubling of power consumption. In the midrange and treble however, the woofers are relativity far apart (with reference to wavelengths), and they do not have that efficiency boost of 3dB. This will be to your advantage because at high volume the tweeter will not stick out like a sore thumb, as it probably does now. I have my doubts about all those "high efficiency" midwoofers. Sure, their midrange is efficient as anything, but they never seem to have huge rubber surrounds to cope with their just as highly efficient bass performance.😕
CM
CM
Just on the subject of the ADAM speakers, I was lucky enough to have a quick demo of them, and a chat to their chief sales guy over a beer last year at IBC in Amsterdam. The drivers are AMTs, proprietary to them, and not rebranded, and sound pretty damn good. The rep was interested to hear that the diy community are always interested in new tech, but pointed out that ADAM, as a relative newcomer, needed to get a market base established for its main products before selling components. But he didn't rule it out...😉
Thanks CM;
I have been wondering- I know that in many MTM or MTMM or whatever designs, people often only use one woofer for the mid band. For a mtm this is often called 2.5 way design- I understand that this is important because it is preferable not to have such a large radiating area for the mid range speakers- Is this more or less correct?
So my felling is a dedicated mid would;
Mate with a ribbon better-
-and-
have less IM and doppler effect caused by the same driver being responsible for High xmax frequencies as well as delicate mid freq-
BTW; I am not really attracted to the PA style speakers- although I do know that many are very good-
Also- The Aura is an aluminum cone driver- I am all for stiff cones- llke I said I like the puchy modern sound wich is usually (in my experience atleast) associated with stiffer cones
Can you recomend any Mid-Bass drivers that I should consider for this purpose? What about the Jordans? maybe the jx125? Or a seas excel maybe?
pinkmouse;
If those woofers are proprietary to ADAM then sombody has a bulletproof lawsuit on there hands- The both use the word "hexacone" to describe their woofers if they are not eton's then there is no way they can both use the term hexacone- and by the way they look identical too!! Maybe they are made by eton specifically for the ADAM monitors though- (and the tweeter could be different but they look real similer to me) Either way I am not super attricted to the eton line anyway- thanks again,
Ryan
-and-
pinkmouse;
Ryan
RyanC said:...Can you recomend any Mid-Bass drivers that I should consider for this purpose? What about the Jordans? maybe the jx125? Or a seas excel maybe?...
Of the Auras, Jordans, and Excels, I think the Excels are the best. I was intrigued by the E J Jordan speakers though: they use extremely thin "profiled" metal foil cones in their designs with very well controlled cone break-up modes at high frequencies. Dunno about the longevity of such speakers under sustained high volume though. Nevertheless the waterfall plots look much nicer than anything I've seen for paper cones...
Visaton do a 3" titanium dome midrange I think.
It all depends on what you have in mind for the woofer. Visaton speakers and Seas (Excel or Standard) speakers are probably quite safe bets for both bass and midrange.
You'll have to consider how big you want the enclosures to be, ported or sealed, and choose a woofer to suit. I think I might be able to help with designing for a "punchy" bass sound via unconventional tuning of a ported box (which requires a smaller than usual box), but I'll only know for sure in a few days after some more DIYing.
An Excel W18EX001 could be good for a midrange speaker. I think that a low electrical Q factor (Qes) means that internal box resonances can't escape through the cone that easily, but it also means that the magnet has to be large. For a Seas midrange I'd also consider: W15CY001, W12CY001, L12RCY/P, L14RC/P, L17RE/P, L18RNX/P, L18RCY/P.... Note that many of the measurements of the Seas site are not made with a standard large baffle, so the bass performance might look bad even if it's not. All of those should go to around 3kHz without problems, but the best size for you will depend on things like max power, bass, and sensitivity.
Eton actually seems pretty good to me for midrange performance. Their cones are made of two layers of kevlar fibre or something similar, with a honeycomb mesh material in between for extra thickness. This achieves a competitively stiff cone (in the same league as Al or Mg alloy), but without the metallic 5kHz to 10kHz ringing of the Seas cones.
CM
- studio monitors
