Overkill?
Overkill?
Old 10th July 2018, 09:36 PM   #1
nigelb63 is offline nigelb63
Default Overkill?
L-pad plus a Zobel. is this overkill?
Old 10th July 2018, 11:43 PM   #2
adason is offline adason  United States
adason's Avatar
Those two have different function, so its not a right question. Sometime you do not need any, sometime just either one, sometimes both...
Old 11th July 2018, 12:17 AM   #3
kevinkr's Avatar
Overkill?
I've not seen any applications so far with LPADs where a Zobel was required.
Zobels are useful when a driver is connected directly to a passive crossover network in order to assure that the load impedance presented to the network remains relatively constant in the passband and stopband of the network.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 11th July 2018, 11:24 AM   #4
AllenB is offline AllenB  Australia
Sometimes, even when attenuating several dB the resonance peak has a significant effect with tweeters. I sometimes find it useful to do both. On the other hand, when measuring and simulating, the answer should be clear.. Whatever works is OK. In my case I have a reason, it allows simpler changes free of the irrelevant impedance effect. Otherwise, keeping it simple is good too.
Overkill?Hide this!Advertise here!
Replace overkill caps with even more overkill caps? hansibull Parts 13 22nd April 2014 08:31 AM
Is this overkill for an F1? milezone Pass Labs 7 18th August 2009 02:13 AM
My new amp design - the Overkill 180 jgedde Solid State 13 16th March 2008 03:52 AM
when does bass get to be overkill? scottr0 Subwoofers 54 21st March 2007 06:51 PM
B+ TX. overkill? Richard Ellis Tubes / Valves 2 26th September 2006 09:12 AM
