KEF LS50 - crossover?
Old 3rd July 2018, 11:52 AM   #1
Soldy is offline Soldy  Germany
Default KEF LS50 - crossover?
does anyone know the schematics of the crossover of the KEF LS50?
Greetings,
Soldy
Old 6th July 2018, 06:09 AM   #2
nimo_jon is offline nimo_jon  Singapore
There are examples:
Kef LS50 Crossover upgrade - DIY Audio Projects - StereoNET
Old 6th July 2018, 06:36 AM   #3
Thank you, but thats just the crossover part for the low midrange woofer. I was hoping for the tweeter part of the crossover
Old 6th July 2018, 08:01 AM   #4
system7 is offline system7  United Kingdom
system7's Avatar
It's always want, want, want here!
Oh well. I'll bite. Looks to me like the circuit on the left is the LS50 original. Suprisingly simple.
That's just a bass coil and a second order tweeter with a resistor for level.
Must be 3kHz crossover. Why do you want to know?
Best Regards from Steve in Portsmouth, UK.
Old 6th July 2018, 08:10 AM   #5
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
LS50 Schaltung Topo | ls50schaltungtopo | hifi-forum.de Bildergalerie
Old 6th July 2018, 08:46 AM   #6
system7's Avatar
I did look at the links yesterday, but found it all very difficult in German.
KEF LS50 - crossover?-kef-ls50-3-jpg
But maybe some progress. The left section is a third order bass then.
That makes sense for a good speaker. The tweeter filter looks like a glorified second order in the image below. I can't guess the polarity with this coaxial.
And the section below that, called "Neu" might then be a new bass section.
Which still leaves me scratching my head on a new tweeter section.
Old 6th July 2018, 09:35 AM   #7
Thank you guys.
I am familiar with the German thread and even had contact with the guy who posted it. But unfortunately, he only knows the part of the crossover that is responsible for the mid woofer. And due to copyright, none of the images show the whole crossover.
@Steve: Neu means new -> it only shows his modified part of the woofer crossover
Old 6th July 2018, 09:57 AM   #8
system7's Avatar
My German does extend to "Neu" as it goes.
How hard can this be, really? SEAS make the coaxial Loki with a 6" bass.
SEAS Loki MkIII
To make the bass third order, you would split the 2.2mH bass coil into about 1.8mH before and 0.4mH after the capacitor. You often put a little resistor across the 0.4mH. Which might be 5 ohms here. It ends up similar.
The Loki is a 3kHz cross to the tweeter.
Old 6th July 2018, 12:56 PM   #9
Thx Steve, if no one has the schematics I will try this
Old 6th July 2018, 02:18 PM   #10
system7's Avatar
My intuition, based on what I have seen here is something like below might work. 3kHz crossover for a 5" metal bass.
I really have no idea about polarity, but this can't be way off. The tweeter is effectively horn loaded, so the input 3.3uF capacitor is always smaller than you might expect.
I haven't attempted an 7-8kHz bass notch on the breakup.
KEF LS50 - crossover?Hide this!Advertise here!
KEF LS50 jerryo Multi-Way 133 29th March 2018 10:22 PM
Pass labs amp for Kef LS50? stephenmarklay Pass Labs 8 26th January 2018 02:33 AM
KEF LS50 polars Hifisound Multi-Way 0 6th December 2015 07:43 AM
Amazing new KEF LS50 Remlab Multi-Way 3 3rd December 2012 10:51 PM
