Generating driver FRD setup questions for passive xovers
Old 10th July 2018, 08:19 PM   #21
SyncTronX is offline SyncTronX  United States
SyncTronX's Avatar
Here is the pic, differences will be the following:
Different Tweeters-Accuton Different MidRange-Seas
Same Woofers-Etons 2 per speaker outward firing.
I'm wondering how to reconcile each of the speakers two opposing side firing woofers? How do I not pic up reflections.
Oh, but these should be measured both near field centered just off the dust cap of each. Then far field but is this for each driver? I think I have to move to the front somewhere for proper measurement of the whole system yes?
PS - It helps if I remember to attach the pic.
-- Sync
Old 11th July 2018, 04:37 AM   #22
kimmosto is offline kimmosto  Finland
Use measurement gear and method linked earlier, and simulate with VituixCAD.
Example project: Taipuu 4-way, though average elevation of woofers is "typical" - not on the floor generating maximum vertical room resonance. Suitable level for woofers is not so simple to design/decide as passive. Adjustable (semi)active system would help in practice.
Old 11th July 2018, 07:06 PM   #23
SyncTronX's Avatar
I have a loaner mic that is calibrated, no calibration file. Sound card is an issue though. I would use laptop with windows 10.x I do have licensed ARTA, but haven't used it as I don't have good soundcard. turning table...I think the Lazy Susan I'd use isn't rated high enough for a speaker.
Table height? Not sure.
I also have a mic measurement amp/pre amp that I've trouble shooted. Not sure how it would work, oh boy.
I also have other stuff. How Does REW work, compare?
-- Sync
Old 11th July 2018, 08:27 PM   #24
Bergarth is offline Bergarth
Default THanks
This post is awesome! I have been banging my head all week trying to learn PCD= What dosnt help is i keep changing the drivers haha because PCD is not helping as much as i like and im not getting my F3. Anyway, i book marked this and will read this again and again along side other tools. Now i can stop going nuts and just pick some driver i want that will do about what i need and go from there. Whats nice is i posted a thread "what do you think" with drivers i found that are ok in PCD but on paper meets and exceeds desires, i got a oky crossover mocked up already in PCD but now i know i should just order drivers and go this route and it should be even better
Generating driver FRD setup questions for passive xoversHide this!Advertise here!
Generating .frd and .zma files from REW for use with Passive Crossover Designer robotc Software Tools 0 24th September 2014 10:05 PM
Passive sub Xovers Rodastro883 Multi-Way 5 4th December 2012 05:48 PM
Active vs. passive Xovers Ryan_Mc Multi-Way 14 5th November 2008 03:31 AM
Passive line level Xovers Tenson Multi-Way 2 9th August 2006 09:14 PM
Capacitors for passive xovers. JoeBob Multi-Way 1 14th December 2001 01:46 AM
