The project states
Speakers are Jamo studio 120
intervention, replacement of the mid driver with a open back driver instead of the capsulated driver and encloseit in a cilinder.
pirpose is hope of better vocal reproduction
question is: where in the xo I put one more capacitor to make the mid receive a little more of the low freqs?
Look for the cap that's already there
You should find a capacitor in series with the existing midrange. Simply increase it's value or add a small capacitor in parallel with it in the crossover. However, if you change the midrange, you will very likely need to make other changes to the crossover to adjust for different impedance or efficiency relative to the original. I suggest taking a look at some crossover design software like Xsim.
