Old 17th April 2004, 01:03 AM   #1
ShinOBIWAN's Avatar
Default Help! Finish gone bad
Earlier today I sprayed a speaker I've been working on for a while now.
Because of the fumes etc. associated with spraying I chose to do it outside. Now after the job was finished I left the speaker outside to dry.
I've now just recently checked it and its gone a misty white in places.
What has caused this and can it be remedied with another coat or does the whole thing have to sanded back to the wood?
I should also add that this particular coat was added over 2 earlier coats and these took fine. Its just that the 3rd and last coat has gone tits up!
Old 17th April 2004, 01:14 AM   #2
Is it humid in your area, or has it recently rained?
Old 17th April 2004, 01:25 AM   #3
ShinOBIWAN's Avatar
Yep it had been cold over the last few days here, so it had just finished raining when I saw my chance to go give it the last coat.
Is this the cause of the frosting effect that I'm seeing on the matt black finish?
Old 17th April 2004, 01:27 AM   #4
It happens even when the weather is just cold. I know of two carpenters that have told me this is the cause. I've experienced it before too, and here in Australia it doesn't get as cold as where you are in the UK.
You should generally be sanding between coats either way, just a light sanding with 220grit sandpaper to make it smooth. Sometimes it isnt needed though, but I've found its a good idea.
I think what I did about the misty stuff was to give it a light sanding all over, then I sprayed another coat of laquer when the weather was warmer and let it dry and the misty white stuff disappeared.
Old 17th April 2004, 01:58 AM   #5
HTRookie's Avatar
What has happened here is moisture has been trapped in the finish, causing it to 'blush". IF the finish is lacquer.. simply purchase a can of lacquer thinner, if you an get one, and lightly spray on a misting coat.. The thinner is miscible in the lacquer, and will soften the finish enough for the moisture to escape..
If the finish is varnish or similar.. you wil have to abrade the finsih and start over
Best of Luck!!
Old 17th April 2004, 05:22 AM   #6
First off you have to tell us what type of finish you applied. I am definately not a fan of any type of finish that you spray on. Profin is just too easy to apply and smooth-wipe to let a finish sit on the surface without dragging it through.
I would wait at least a week before you did anything. Depending on the type of finish you use the moisture will escape over a short time and the white will be gone. This can happen with a Swedish finish used on floors. If you get a large amount of water on it it will get in the finish and white spot it. Giving it time to dry and evaporate out can reverse the whitening completely.
If a week goes by and it doesn't fix itself I would try to sand it down with 220 grit till the white is gone then try another coat.
Good luck.
Old 17th April 2004, 06:34 AM   #7
Bill Fitzpatrick's Avatar
Tell us about Profin and where to get more info. I tried a Google and didn't get any results that seem to relate to furniture finishing.
Old 17th April 2004, 07:07 AM   #8
Profin is a products put out by Daly's - a paint and finish company. It is also commonly carrried by Home Depot and Lowes - at least in the Seattle area. It is an oil based finish that does not yellow and is best applied in thin coats. Three coats gives a great finish, with 4 to 5 coats getting you a deep, revealing finish.
Most high end GC's I know like it for its protective properties and stability. It is also pretty easy to apply. It has worked well for me on trim and furniture in the past and is stable over time. I do not know if it is a local company or if Daly's is national but the is is easy to use and has great results.
I looked up their page - here:
http://www.dalyspaint.com/products.htm[/URL]
Oh yea - I LOVE benite - have trouble with getting stain to look uniform - Benite is the awnser!
Old 17th April 2004, 09:12 PM   #9
ShinOBIWAN's Avatar
Thanks for all the advice everyone.
In the end I just gave it another coat and left it to dry in the sun.
Looks fine now, so its a happy ending.
Old 8th May 2006, 07:15 PM   #10
Vikash is offline Vikash  United Kingdom
diyAudio Moderator Emeritus
Vikash's Avatar
I just did the same thing! Argh!!
I washed it down with clean water after sanding some sides and applied another base coat (the last one was applied over a month ago) and I don't think I let it dry long enough (~15 mins) although it appeared completely dry
Gonna try another coat in a bit and see what happens...
"The human mind is so constituted that it colours with its own previous conceptions any new notion that presents itself for acceptance." - J. Wilhelm. (But I still think mine sounds better than yours.)
something to finish mdf paulfk Multi-Way 14 14th March 2009 03:04 PM
Does anybody know how to get this finish? wrl Multi-Way 177 30th January 2008 10:15 AM
MDF Finish bjackson Multi-Way 26 4th June 2005 12:41 AM
Enamel finish bjackson Multi-Way 11 26th April 2005 08:40 PM
Wood finish fireman Multi-Way 15 25th October 2004 08:06 PM
Page generated in 0.11075 seconds (79.53% PHP - 20.47% MySQL) with 10 queries
