Old 8th May 2006, 11:34 PM   #11
ShinOBIWAN's Avatar
Originally posted by Vikash
I just did the same thing! Argh!!
I washed it down with clean water after sanding some sides and applied another base coat (the last one was applied over a month ago) and I don't think I let it dry long enough (~15 mins) although it appeared completely dry
Gonna try another coat in a bit and see what happens...
Wow, nice thread ressurection Vikash. Over 2 years old
I remember when this happened. This was when I first started spraying.
Its just so maddening because the effort involved with sanding is a bit gauling when you realise you just wasted your time.
Be sure to check out the BBC weather website and enter your postcode to get a pretty specific summary of the weather conditions in your area. My advice from previous experience is not to spray if the humidy level is 70%+ and prefereably less than 60%. Always try to pick a nice days with minimum clouds and good sun, the paint always dries quicker between coats and you get zero moisture trapped in the finish (clouding). Of course if you spray in a warm and well ventilated garage then ignore this.
If you must spray outside on somewhat damp days, do it undercover and I also use two patio heaters spraying heat over the work. I haven't had any problems with this method but I generally leave it until a decent day unless its urgent.
Old 7th July 2006, 11:35 AM   #12
ShinOBIWAN's Avatar
What happened to the rest of this thread? There were around 3 pages more when I visited yesterday.
Old 7th July 2006, 11:50 AM   #13
pinkmouse's Avatar
Vikash has been doing some housework.
Discussion about gloss paint finish technique
Have you had chance to get to the PO yet?
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 7th July 2006, 11:54 AM   #14
ShinOBIWAN's Avatar
Thank Al,
I've just got back from a trip into town and dropped a couple of parcels off at the post office including your AV15. It will be with you mid next week.
something to finish mdf paulfk Multi-Way 14 14th March 2009 03:04 PM
Does anybody know how to get this finish? wrl Multi-Way 177 30th January 2008 10:15 AM
MDF Finish bjackson Multi-Way 26 4th June 2005 12:41 AM
Enamel finish bjackson Multi-Way 11 26th April 2005 08:40 PM
Wood finish fireman Multi-Way 15 25th October 2004 08:06 PM
Page generated in 0.08310 seconds (72.92% PHP - 27.08% MySQL) with 10 queries
