I have been considering building a pair of Klipsch Jubilee clones - but a couple of sneaky individuals here and elsewhere have convinced me to go all out and build Klipsch MWM stacks instead. Parts will be ordered on Friday..... I even managed to find an excellent local source of BB ply at a very reasonable price.
So I will end up with a total of four 15" drivers in big horns, plus the two Klipsch K402 horns on top. I'm not looking to drive these to foolish levels. Amps will probably be SET or Class A DIY. With circa 108db sensitivity, I wont need much....
But it dawned on me today to ask some opinions about my room size. The wall the speakers will corner into is 7m long, with a 2.7m ceiling height. The side walls are 6m long, then they meet some 1.5m returns (remains of an old wall now removed). The space behind the returns is another 6m x 6m, with open plan kitchen extending out. Lets call it a space greater than 6x12x2.7.
The k402 will be centered at about 1.1m height. I will have some flexibilty in terms of spread and toe angle with the big bins. I reckon I could sit about 4m from the speakers for critical listening, given that they extend over 1m into the room. Often the system will just be playing while we live in the space.
I know the MWM are designed for huge spaces / outdoors. Does anyone see any fundamental issue with my plan based on the space described? Thanks.
Thanks Chris - good point. I will be using Crites woofers, which I understand to be fairly similar to the old K33. From what I can gather, these should provide extension below what the more recent (K43) drivers offer in these bins. I expect they should approach the Khorn 35hz mark. But that remains to be seen.
I'm no crossover designer and I was hoping to avoid multiple amplifiers and active crossovers, so I am a little limited coming up with reflex bins to mate up to the K402. Bob Crites is doing the hard yards for me with the crossovers - and he has high praise for the MWM bins. I can also use these outside which is a nice feature over summer.
If there is not likely to be any room related issues, I'm comfy with the MWMs, but if you have an alternative that is smaller footprint with better performance on most fronts, I would consider it.
I'd expect a large bass reflex to get considerably lower than 35Hz, but efficiency will drop. You could probably get another octave of extension, and with 2x15" per side, efficiency could still approach 100dB@1w.
It's all a compromise. If you're happy with just about getting to 35Hz, then carry right on. I, personally, am happy to throw a bit of power around if it means I get a useful improvement in low-frequency extension. Personal choice.
You're on the road to a really nice system, either way.
Chris
Chris
You might consider taking some kind of paper (as in a roll of paper) and make a template so you can put it on the floor and get a real-world idea of how they will impose into the room.
I don't remember the size but they are approximately six feet, 2-meters wide (perhaps a bit wider....here is a picture of one in my eight foot wide bucket.
None the less... they do not go to a "point" in the back so you will have some dead space back there. Meaning, they will take up the entire corner out to a certain distance (because of the width) but, they won't look that "deep" because they're truncated.
I don't know if that makes much sense... so cutting a template will give you a real world idea of their intrusion into the room.
For home use, the K33 should be fine. (If I understand Bob's story correctly, he called the manufacturer, said he wanted to buy say, 50 K33's and was told those are exclusive to Klipsch.... so, he calls them back and said "I want to order 50 "Crites" drivers and I want their TS parameters to be.... and proceeded to give them the exact values of the K33's so the stamped frame should be an exact K33 with his name on them (unless he's changed something in the meantime)
For indoor use, it will be WAY more than enough. For outdoor use, it will probably be enough (it was for us doing a movie and a DVD concert outdoors) but if you play them outdoors, you might consider going conservative on the fuse so that your "K33" doesn't turn into a fuse protector instead of the other way around!!
Last, I'd urge you to build some handles into those darn things. The doubles I have are slippery little devils and very awkward to carry around. The singles I had (sold them) hand handles and that made them MUCH easier to move.
Joined 2009
So I will end up with a total of four 15" drivers in big horns.......
Been there, done that for several decades until I was forced to sell off some stuff to keep my house, winding up with just my two dual 15" 'subs' using the same Altec 515B drivers like in the ~35 Hz corner horns and frankly, while I miss some of the super high efficiency perks; all things considered I much prefer the drivers in the large, corner loaded MLTLs, finally understanding why the great horn designer Dr. John K. Hilliard chose IB loaded dual 803 [416A] for his seemingly large, open, yet still acoustically fairly small home system:
https://ia902502.us.archive.org/Boo...Mar_0000.jp2&scale=6.429872495446266&rotate=0
https://ia902502.us.archive.org/Boo...Mar_0027.jp2&scale=6.429872495446266&rotate=0
GM
GM
GM.. I will hopefully be able to re-use all the gear to do MLTLs if space eventually dictates (except the XOs of course). I always keep your words in the back of my mind.... Thanks.
Tell your friends you got the MWM speaker stack when you set up for the Grateful Dead.
Sound Quality vs. Sound Quantity
The K402 over Jubilee gets very good reviews for natural sound quality. Invest in a few room improvements, along with measurement+equalize equipment.
You could purchase a second set of plastic K402 horns and build/experiment a 200Hz Synergy horn which promises better sound quality, plus a good path to room-equalized deep bass. Plans for a wood K402 are on the net.
what you guy think of this?
Looks like an Altec / WE hybrid... Beautiful! That has given me an idea... Seriously!
Going big for the right reasons is very good. It is possible to waste space if not thoughtful.
Agreed, my post wasn't about space savings/efficiency, just I found I preferred the more 'open' sound of a large horn size flat baffle loading the drivers in a corner horn configuration over the corner loaded compression horns.
If I could afford to build a whole new system it would have [8] HE 15"/channel to get efficiency up 'close enough' to the HF horns.
GM
Yep, typical big systems discussed/built on most forums are all about efficiency/SQ in a HIFI app, not how loud they play per se. To go 'live' OTOH takes a bit more: 20,000 Watt Home Hi-Fi System
GM
Don't much like the multicell crammed into the mid horn, though depends on the XO as to whether it messes with the critical mids that these big horns do so life-like, but otherwise like it.
Looks like early 15" Lansing/Altec 515? assuming the mid horns are WE 15, though baffle depth appears to be too shallow for a reflex. Makes me wonder if it's some kind of weird hybrid OB.
My Altec 515Bs have a ~97 dB/m mid band efficiency, so [8] would be ~106 dB/m down low where there's good coupling efficiency.
GM
Ive had Jub clones... Amazing. Id sugest not doing the MWM, The Jubs are vastly more interesting and an easier package to live with. Ultimately I sold my Jubs as they were too big for me let along my wife. If you go down the Job route, PM me. We developed a 2nd order crossover... All passive crossover... A SET 45 amp will make them sing.
- Is there such a thing as too big?
