Any experiences with Faital 12PR320 : 12" driver for 40-500 Hz
Old 14th June 2018, 08:23 AM   #11
zmyrna is offline zmyrna  United Kingdom
your choice of mid and bass drivers both have the same Fs of 42hz
i'll say that and leave it there
in troels' dtqwt, 8" and 12" fire into the same horn; the benefit is that there is no high pass filter on the 8" (saves a lot of $$$ by avoiding the large expensive capacitor). you are not getting any bass from that 12" unless you build a tapped horn or tqwt.
Old 14th June 2018, 10:36 AM   #12
scholl is offline scholl  United States
Not those but I use the 310s and I'm very happy. Nice punchy sound and good vocal tone. I get an honest 55hz low end at 96db.
Old 14th June 2018, 08:44 PM   #13
gug42 is offline gug42
Thank you ! great news I'm must know think about the all thinh
By the way any recommandation for the inside volumes, for the 12PR320 ?
Old 15th June 2018, 10:30 AM   #14
With a qts of .37 you can go as large as Vas. Run the numbers and build larger rather than smaller. You'll get bass typical of a 15 but in a box typical of a 15 too. It'll make a nice two way crossed at 1.2K-1.6K.
Old 15th June 2018, 01:09 PM   #15
KaffiMann is offline KaffiMann  Norway
KaffiMann's Avatar
Location: Grua, ten minute walk from 60.258792, 10.664731
Ref: my first post, it looks really good in 108 liters, but here's a slightly smaller box at 101 liters in 2,83v/2pi:
I do not mind sharing the numbers, but thought you might like to fool around with simulations yourself first.
Note the slow roll off, I have found that I personally prefer this type of frequency response to completely flat to some point, it gives very good group delay and very smooth phase. Sounds like a closed box, but goes deeper.
Old 15th June 2018, 02:37 PM   #16
Hello,
Evryone, thank you
@KaffiMann : you are right thx
@scholl : Hum sorry for the dummiers question, what is a "typcial 15" volumes ?
Thank you in advance !
Old 15th June 2018, 07:45 PM   #17
Originally Posted by gug42 View Post
Hello,
Evryone, thank you
15" woofer. If you run the numbers on the 12pr3xx they model like some 15" woofers. Compare them to a JBL 2226h and see what you get.
Old 15th June 2018, 07:56 PM   #18
Oh well, The doc speak about a 140L boxe !
The frequency response and the sensibility of the JBL seems to be a little better. There price is higher
Any experiences with Faital 12PR320 : 12" driver for 40-500 HzHide this!Advertise here!
faital 8"/10"/12"RS series for 30 liters hormilo Subwoofers 0 8th May 2017 02:20 PM
Want to Buy 1.4" driver Faital etc... exurbia Swap Meet 0 4th June 2016 04:35 PM
german brand "gradient select" drivers? experiences? butterwitz Multi-Way 14 7th February 2015 12:42 AM
Faital Pro HF144 hf driver & 8 cell horns JRKO Swap Meet 0 5th July 2014 09:58 PM
Faital Pro 3FE20 - anyone here try this interesting driver? freddi Full Range 14 27th September 2012 01:54 AM
