Where do most perceived detail come from, tweeter or woofer?
Old 30th May 2018, 06:01 PM   #1
Navyblue is offline Navyblue  Singapore
Default Where do most perceived detail come from, tweeter or woofer?
I guess this depends on the sound material and crossover point. How about for vocal and most musical instruments, at a typical crossover point of 3kHz.
I am under the impression that most perceived detail or texture of music comes from about 5k to 10k Hz. If so does it mean that we should put more money on tweeter when building a speaker if detail is the priority?
Old 30th May 2018, 06:12 PM   #2
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
A flat(ish) frequency response is the priority
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Old 30th May 2018, 06:35 PM   #3
So as long as we EQ them just right, we can make $1000 speakers into $100000 ones?
Old 30th May 2018, 06:49 PM   #4
chrisb is offline chrisb
I'm thinking Scott was more suggesting that natively flat-ish FR of the drivers not requiring excessive EQ - not to mention crossover networks not getting in the way - would be more of a design objective.
Out of curiosity, have you heard any $100,000 speaker systems that you'd sell a kidney for?
like my mind, this space intentionally blank
Old 30th May 2018, 07:02 PM   #5
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Detail comes from all the drivers ability to reproduce small detail… i use Allen Wright's term DDR (Downward Dynamic Range) to describe this. It needs to be in the tweeter and the mid bass (or FR or other drivers). A cross-over is likely to remove detail — or at least stir up the timing of its arrival. FR as we measure it is like the surface of a body of water… clarity at the bottom is where the detail resides.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 30th May 2018, 07:07 PM   #6
nezbleu is offline nezbleu  Canada
nezbleu's Avatar
Try disconnecting a tweeter then a woofer, see which most affects your perception of detail or texture.
"In the world of commerce and finance it is thought quite remarkable if a man is both clever and honest." -- Demosthenes
Old 30th May 2018, 07:09 PM   #7
You might find this thread interesting, the discussion morphs into one examining how much can be achieved by EQ Who makes the lowest distortion speaker drivers
Old 30th May 2018, 08:00 PM   #8
I am fortunate enough to have heard a pair of Kondo horn speakers that the owner said cost about 80k Euro, which work out to be about 100k USD. Previously I have not known this level of realism, sound stage and impact is possible.
I don't know what model, I tried googling can't find it either. I have no idea how much the rest of the system cost.
Old 30th May 2018, 08:08 PM   #9
andy2 is offline andy2  United States
Sin Bin
I have to say both. It's hard to say which one is more important. A good woofer is not complete without a good tweeter and vice versa. Like Ying and Yang - they are both sides of the same coin. Neither one can exists without the other.
Old 30th May 2018, 08:15 PM   #10
You might have missed the OP. As stated IMO 5k to 10k Hz range is most responsible. But this is from a layman perspective.
Disconnecting a woofer and putting a cheap woofer are far from the same thing.
For bass driver, IMO an expensive driver and a cheap one would make little difference in most cases. Very little musical information reside in that frequncy range and our ears are not that sensitive at that frequencies anyway.
Now between bass and upper midrange, this is not so clear to me.
Where do most perceived detail come from, tweeter or woofer?Hide this!Advertise here!
Best Mid and Tweeter upgrades for resolution of detail? bmwparts Multi-Way 95 23rd November 2017 04:13 AM
Woofer-Fullrange-Woofer vs Tweeter-Midrange-Woofer fakeout Multi-Way 5 11th August 2012 06:17 PM
SPD - Subliminally Perceived Distortion Jack Caldwell Everything Else 126 7th June 2011 10:57 PM
perceived gc phenomenon tryonziess Chip Amps 4 12th June 2007 08:45 AM
