Old 13th May 2004, 03:15 PM   #11
Sealed box loading is indicated, though the driver would
work best driven by lowish power and used open baffle.
The driver is not a good subwoofer driver.
Fs is far too high, an octave lower (27Hz) or lower is better.
Qts is also too high, for reflex ~ 0.35 with low Fs is good.
Its a passable bass unit for a big cheap speaker at best.
Low Fs, moderate Q, moderate Vas, reasonable efficiency
and high excursion with low distortion are good.
sreten.
Old 14th May 2004, 08:50 AM   #12
sonu is offline sonu  India
OK.......
but I wanna know as how to select a best driver i.e. what parametrs i should look for when selecting.
As i have made this driver on my own, I want to know what all affects the change in VAS, Fs, Q etc for a driver.
Cause now i am making an 15" Driver, so i will select cone, coil, frame and magnet which should give a good thiele parameter as needed.
Old 14th May 2004, 10:38 AM   #13
lucpes is offline lucpes  Europe
Send a message via Yahoo to lucpes
Edit: Ok, sorry, I know that you did all this but it should help others:
http://www.mhsoft.nl/messen_en.asp - measuring T/S parameters on your own.
You can use a computer with a soundcard for an audio generator:
http://www.nch.com.au/tonegen/index.html
Then, to calculate box/tuning/ported or not, download this:
http://www.linearteam.dk/default.aspx?pageid=winisdpro
Enclosure volume for HiVi B3S sploo Multi-Way 2 3rd April 2007 02:14 PM
Enclosure Volume Mat_89 Subwoofers 3 19th September 2006 11:27 AM
Help calculate enclosure volume Sillyboy Multi-Way 25 6th May 2006 12:22 AM
Sub: Volume of Enclosure with Amp bigkid Multi-Way 16 19th July 2003 07:12 AM
Enclosure Volume r_s_dhar Multi-Way 16 13th August 2002 07:24 AM
Page generated in 0.12864 seconds (48.00% PHP - 52.00% MySQL) with 11 queries
