Tannoy VX12 Box designs
Old 15th May 2018, 11:44 PM   #11
PeteMcK is offline PeteMcK
IIRC, the older concentrics were low Q drivers, & best suited to an EBS alignment if you wanted low bass....
Impedance varies with frequency, use impedance plots of your drivers and make crossover calculations using the actual impedance of the driver at the crossover frequency
Old 16th May 2018, 12:37 AM   #12
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Measured results that i used for the Tannoy 12DC Gold box.
Tannoy VX12 Box designs-tannoy-12dc-gold-tsp-png
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 16th May 2018, 07:20 AM   #13
Charles Darwin is offline Charles Darwin  United Kingdom
Originally Posted by aquapiranha View Post
Hi and thanks for the reply. What makes you think I wouldn't get any bass out of them in a different cabinet? Is there something about the drivers I am missing? Thanks, Steve
It is one of Tannoys modern PA drivers and a fair bit more efficient than their classic 12s. To get that efficiency Fs will have been raised quite a bit higher than that of a 12" Monitor Gold, HPD or K3149.
Since it was never meant to be used without a bass except as vocal PA that is not a problem in its intended application.
I think the model number of your DC is either 3140 or 3142.
Old 16th May 2018, 08:11 AM   #14
aquapiranha is offline aquapiranha  United Kingdom
aquapiranha's Avatar
Well, not quite the response I was hoping for...(No pun intended)....
Dear Stephen,
This is relating to case number: 00748711
Unfortunately we are unable to offer much help in this instance as it is against company policy to divulge build information of any of our products past and present. We cannot provide schematic diagrams of crossovers, amp modules, and cabinet designs or T&S parameters of our drivers with any 3rd party that is not an approved FASC (Factory approved Service Centre)
While we understand that many Tannoy fans enjoy building their own loudspeakers as a hobby, or that some schematics may be required for repair, this has led to some trouble in the past which is why we have adopted this policy.
Kind Regards
Christopher Edwards
Your Technician, Care
Music Tribe
Tel: +44 (0)1562 732299
Email: careente@music-group.com
Web: MUSIC Tribe | Home
So, I will have to use a Monitor Gold design and hope that it can be tuned. Any ideas for enclosures? I like RLH designs but I am open to suggestions thanks,
Steve
Old 16th May 2018, 08:12 AM   #15
Hi and thanks again for the informative reply. I will get the model number this evening when I get home from work, cheers!
Steve
Old 16th May 2018, 08:21 AM   #16
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
these are having highish Fs , really made for smaller cabs- stage monitors
no use of having full bass enclosure , you need bass helper with them
simplest Fs measurement will reveal is it 3142 or not
for full bass duty , magic (type) number is 3134 , used in TDM12 and CPA12
but , don't fret - you have awesome base for great spks there
just an idea - put them on OB and use whatever sort of bass helper you like most
example : Tannoy Brute Force OB ….. now Absolute WAF Tannoy OB | Zen Mod Blog
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 16th May 2018, 10:10 AM   #17
Steve
Try asking Lockwood Audio, they might know and in my experience they are more helpful than Tannoy.
Lockwood Audio
Old 16th May 2018, 11:40 AM   #18
Thanks Charles I will contact them later, and thanks all for the replies so far. I will post up the model number this evening assuming it is on the driver
Old 16th May 2018, 12:34 PM   #19
EarlK is offline EarlK  Canada
SNIP
I have previously build enclosures before, not least the awesome Sachiko back loaded horn for the Fostex206E.
SNIP
Many thanks, Steve (aquapiranha)
Nice acquisition!
As has been mentioned any high efficiency 12" woofer ( ie; above 92db ) will surely sport a high Fs, low Qts, and a very small Vas.
As such, there won't be a BR alignment that will produce bass of any consequence.
You are best off ( I believe ) acquiring the necessary Ts parameters and then seeing if a BLH can provide you with meaningful bass response ( assuming you don't want to use a real woofer below this driver ) .
Old 16th May 2018, 12:46 PM   #20
Originally Posted by EarlK View Post
Nice acquisition!
Thanks Earl. If I could I would build a BLH as a preference. There is bass, just not the required rib cage shattering variety! 😁
Tannoy VX12 Box designsHide this!Advertise here!
Benefits of esoteric designs over traditional designs? ReDress Subwoofers 25 2nd June 2015 11:09 PM
trade tannoy gold DC 10" for tannoy gold 10" ;) limono Swap Meet 4 10th October 2012 09:29 PM
Tannoy DC1000 vs Tannoy 609 antonyip Multi-Way 3 6th June 2011 08:25 PM
My Tannoy Monitor HPD 385 in Tannoy Berkeley enclosure is completed. lhgin Multi-Way 0 11th May 2011 03:18 PM
Tannoy 609 compared with Tannoy 615 photomusicfreak Multi-Way 4 27th November 2008 10:27 PM
