Looking for DIY Studio Speaker
Old 10th May 2018, 05:58 AM   #21
Keruskerfuerst is offline Keruskerfuerst  Germany
Keruskerfuerst's Avatar
@Keruskerfuerst : why not mid and sub on top again?
Because of the distance of woofer to the ground. Causes the baffle steps. Does not sound well.
I think, 25 cm Woofer from Visaton, ceramic midrange from Accuton and a ribbon tweeter from Mundorf.
And a woofer unit with 30 cm bass drivers. Separate chamber.
Old 10th May 2018, 07:55 AM   #22
cyberstudio is offline cyberstudio  Canada
Sorry did the OP say this was for studio mixing and mastering? (i.e. looking for something like a nearfield monitor?)
Old 10th May 2018, 07:59 AM   #23
If he talks about something like Focal Scala Utopia, this is not a nearfield monitor.
Old 10th May 2018, 08:13 AM   #24
mixingandproducing is offline mixingandproducing  Germany
thanks to everybody. Of course that is not nearfield! I really get an idea of what UGG is telling me and how to design it.
@Keruskerfuerst : You think One Bass Unit, one mid and one tweeter. then add an extra sub? What would be the advantage? Sounds good too!
Old 10th May 2018, 08:20 AM   #25
But how would you mix music with a Focal Scala Utopia? (Except as a "second ear" to verify if your mix sounds good after you did your work with a near-field.)
I mean no offense: you probably knew this already. But the point of a studio speaker is not to sound great, it is to "translate". If you mix with high-end home speakers I am afraid your mix will sound great only on high-end home speakers.
If you have already got near-fields and you are just building a set of "second ears" please disregard me - I didn't mean to question your question.
Old 10th May 2018, 08:22 AM   #26
Like you sied, first nearfield mixing then the big boys to listen to!
Old 10th May 2018, 08:29 AM   #27
Ok I see. Sorry about that.
Old 10th May 2018, 08:43 AM   #28
hugo stiglitz is offline hugo stiglitz  Germany
Originally Posted by mixingandproducing View Post
I listened to ATC scm 150 asl pro, PMC MB2S-P,
The level really has to be very high, my room is treated by an acoustician and build by me. So there will not be a problem! :-)
then you should definitely look into ATC SCM100 clones K100 Monitor
or PMC MB2 clones WA TL12
both models are a great mixture of nearflield skills for listening but still like big boys to listen too. you don't need two pairs of speakers.. just one good pair
you can activate either using new Hypex Fusion plate amps. if you do everything from scratch it will be a lot of work and you'll need lots of knowledge. alone chosing drivers must be done carefully to fot them together when it comes to phase response and radiation.
Old 10th May 2018, 09:05 AM   #29
Nothing to say sorry about, I appreciate your help!
@hugo stiglitz : I have seen this site before but here in Germany there is no listening room them, right? I always found the ATC models to lack a little bit in bass response. May be adding a sub or dual sub can fix this?
Old 10th May 2018, 09:10 AM   #30
Correction: two woofers with 25 cm, two midrange units and one tweeter.
two 30 cm subs: powerful and precise bass and precise reproduction of mid and high range.
And it is impossible to have a homogenous transistion range between a 15 cm midrange and a 30 cm woofer. Does not sound good.
Looking for DIY Studio SpeakerHide this!Advertise here!
Harman Kardon studio speaker Savon3000 Full Range 5 26th January 2018 11:03 PM
Rogers Studio 1 speaker LF driver. sharkey22 Swap Meet 0 4th December 2017 04:22 AM
Using a 15" Pro Studio speaker for bass Simon B Instruments and Amps 2 28th March 2012 07:14 PM
Help Me Build My Speaker - (based off Pro Ac Studio 100) deckerluke Multi-Way 1 20th July 2009 02:16 PM
Speaker City MTM 6.5 VS. Paradigm Studio 20's SoundQuest Multi-Way 0 22nd October 2002 11:59 PM
