Plastic Unity
Plastic Unity
Old 9th May 2018, 03:38 AM   #11
hollowboy is offline hollowboy  Australia
Originally Posted by Patrick Bateman View Post
If you ignore the flange, this horn measures 16" x 9.5. That means that it will start to go omni around 1080Hz.
I've housed mine in a butchered JBL 4691B cab, so the face is 70x50cm (if you ignore the roundover, about 24"x16") ...still not big enough to be 'perfect'.
For this project, I'm definitely considering the addition of a secondary flare, similar to what Danley / Waslo / Keele do.
Mine was very arbitrary
You can play around with this in Hornresp; you'll see that narrowing the beamwidth raises the output of the tweeter and the midrange.
It took a long time for this to 'click' for me. I initially thought horn gains were all in the low end.
My 2" driver spec sheet says Half Space Sensitivity db@2.83V/1M 85.67
...but because it is radiating into (roughly) 1/8th space, the effective sensitivity is >90dB, even after I've used subtractive eq to reign in the low frequency boost.
This edit signature thingy is seriously hard to find
Old 16th May 2018, 08:38 PM   #12
HIPCHECK is offline HIPCHECK  United States
HIPCHECK's Avatar
Just noticed this over at Partsexpress: TE-8180 1" Horn 22.5" x 10" 1-3/8"-18 TPI
22.5" x 11" 90x40 horn. IIRC the Small Syns is based on the Seos15 which is also 90x40 pattern.
There is this one to. It is 20cm deep and 40x60. If we are building a single unity mid design like SmallSyns this might work to. The price is right on this one at $12 too! BL-409 Plastic Horn Waveguide
Figured I would post it here if anybody is interested. They also have a copy of the NLA QSC horn for $12 if someone was looking.
If a inch of duct tape will fix it, 3 feet should fix it for life!!!!
Old 16th May 2018, 09:00 PM   #13
bwaslo is offline bwaslo  United States
Old guy with soldering iron
bwaslo's Avatar
Plastic Unity
Looks like a nice flat surface for smashing a midrange onto it, though. But the screw-on mount would have to go, don't want a straight pipe between the HF driver and the waveguide on a Unity - would want to saw off the throat at the point it starts to expand and glue on a CD mounting plate (which might not be too easy to do)
[W9MJE] Horn spreadsheet SynergyCalc/; SmallSyns SmallSyns;
Crossover design Xsim; Depot diffusor super-easy diffusors
Old 16th May 2018, 09:09 PM   #14
HIPCHECK's Avatar
Yes it falls into the "some hacking needed" But that is a really decent sized horn for cheap.
Old 17th May 2018, 07:10 PM   #15
bwaslo's Avatar
Plastic Unity
I'd be tempted to try a design with it, if it weren't for the fact the horn is a limited quantity buyout. I already have horns I like so no sense in designing an orphan.
Old 7th June 2018, 08:24 AM   #16
Some 1.4" and 2" options with flat wall sections (and no obvious throat problems) are on the clearance page here:
http://www.loudspeakersplus.com/Spea...show=30&page=1
If I was in the USA, I'd be tempted by a few things on that page.
EDIT: The PH-220 looks like a decent 1" option, but I don't see it at a similarly crazy sale price anywhere. Locally, they are $AUD 79, which a normal, non-crazy price
Plastic UnityHide this!Advertise here!
Glue for plastic to plastic? leadbelly Construction Tips 17 26th April 2018 11:13 PM
Plastic into Oil planet10 The Lounge 8 16th October 2010 06:18 AM
Plastic TLs Geoff H Full Range 24 12th November 2006 02:27 AM
Which Plastic Mats J Multi-Way 4 27th January 2005 12:46 PM
plastic give me a name Multi-Way 4 5th June 2003 04:11 AM
