Completed project: "Fenrir"
Old 12th June 2018, 02:26 PM   #11
Lishous is offline Lishous  Canada
Lishous's Avatar
This looks like an interesting build. It’s the first time I’ve seen that tweeter used in a project and I’m not familiar with Rival drivers. If you don’t mind I have a few questions.
• What are your impressions of the overall sound quality of the Fenrir?
• Is it worth the money compared to other similar builds?
• Are those woofers worth price? They look great. Your impressions?
• How did you like that Wavecor tweeter?
• Would the Fenrir work in a different box with one port?
My brother-in-law is looking for a project of similar size.
Old 12th June 2018, 09:27 PM   #12
wolf_teeth is offline wolf_teeth  United States
wolf_teeth's Avatar
The SQ is really easy on the ears and non-fatiguing. Enough detail to not sound dull, and bass extension and tonal ability is quite exceptional.
If you would like me to compare to other kits, please ask which ones.
The woofers are REALLY worth the price, and likely should cost twice what they do. Basically you get a motor/frame similar to that of Wavecor, and a proprietary cone formula only from Rival.
The Wavecor tweeter goes lower for a 22mm than it has a right to with a low Fs, and a reasonably smooth response. It has low HD as used in this design.
If you made the cabinets no more than 1.5" narrower, this should not affect BSC that much, and the cabinet can be made deeper this way with the same volume specification. If that is your choice, one port can be used as the depth will be more accommodating, BUT- It will need to be of larger diameter than the ports I used. I used 2 due to the angling needed in the shallow cabinet, and the port mach air velocity speed reduction. It would be a minimum of 2" diameter (2.25"+ recommended) to combine the 2 ports into one, and that with an elbow would not fit in my cabinets. Remember that the larger diameter port will also be longer than they are in the box as I designed it.
Let me know if you have any more questions,
Wolf
Photobucket picture pages: http://photobucket.com/Wolf-Speakers_and_more
Writeups/thoughts/blogs: http://techtalk.parts-express.com/blog.php?u=4102
Old 13th June 2018, 09:24 PM   #13
Lishous's Avatar
Well those seem like stellar drivers for sure.
Here is the box that he has in mind. It's a bit smaller on the front and deeper to the back.
Old 13th June 2018, 10:07 PM   #14
wolf_teeth's Avatar
The baffle response will change from my 10.5" x 17.5", and your cabinet volume is too large. It should be 18 ltrs, or about 0.63ft^3. This will further alter the tuning of the port, and the air-spring on the driver.
If you make these kinds of multiple changes applied to this design, I cannot predict how the results will come out, and all bets are off.
Like I said- if you change the baffle more than 1.5", which you didn't, and use a larger singlular vent, your tuning will change and need adjusted in length. I cannot vouch for going larger in volume or also changing the height of the cabs.
You are, however, free to do as you wish. It is on you if you are unhappy with the results. I optimized the design for the cabs I used. The baffles are Parts Express baffles, and I would at least recommend using those.
Later,
Wolf
Old 13th June 2018, 11:42 PM   #15
Lishous's Avatar
Thanks for your input. I think he will stay with the original design as not to screw it up.
Do you know anything about the Rival Kevlar drivers that are on sale now? I'm wondering if they the same quality. I may order some before the price goes up. They say on the site that they are new drivers so you may not know anything about them. Just thought I would ask.
Old 14th June 2018, 08:00 AM   #16
wolf_teeth's Avatar
I have a set of Kevlars awaiting use, but that model is slightly different than mine. Anything Rival makes is exceptional at the price sold through RAD.
Have fun!
Wolf
Old 14th June 2018, 10:01 AM   #17
Bill poster is offline Bill poster  Thailand
Bill poster's Avatar
How do those wavecors measure up against the small format Seas tweets in terms of sound?
Old 14th June 2018, 12:18 PM   #18
Lishous's Avatar
I like Kevlar woofers and I think their price is very good. Do you think the new Dayton silk tweeter will be a good match? I don't see any reviews of those yet. Do you know anything about those? I'm torn between the Dayton and the new Peerless DX25BG60-04. Am I off base? Should I be thinking about a higher grade tweeter?
Sorry, I don't mean to hijack your thread.
Old 14th June 2018, 01:06 PM   #19
wintermute is offline wintermute  Australia
just another
wintermute's Avatar
Nice. Curious to see the Unibox step repsonse too It models very nicely!
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 14th June 2018, 05:21 PM   #20
joetekubi is offline joetekubi  United States
Dude, unless you are an experienced crossover designer, just build Wolf's Fenrir design. Very hard to do better.
If you want to design your own, the PE RST28 should work great, or you could use one of the SB tweeters
Hope this helps
Completed project: "Fenrir"Hide this!Advertise here!
Finally completed "Delta" enclosure (pics) David Gatti Multi-Way 39 26th April 2012 12:27 PM
"Trichotomy" A completed pair of 2-ways... wolf_teeth Multi-Way 4 13th November 2011 03:42 PM
"Proac 2.5 clone" or "Elsinore project" Joel Wesseling Multi-Way 10 26th May 2011 05:51 AM
Photos of completed Tapped horns, from "Collaborative TH" thread neddludd Subwoofers 3 3rd May 2010 11:36 PM
First Project Completed - Dual 10" Subs 69stingray Subwoofers 8 21st July 2005 03:25 AM
