Hello all,
I have been presented the task of building a sub for music reproduction. My plans are to use an Adire Tempest. a 200 litre enclosure is my limit on size. This gives a Q of .61 which is not as low as i'd hoped. the target is more like 260 litres for Q .59. Option A, Question: how much will fibreglass loft insulation increase the apparent volume? Also i read a while ago somewhere that "stuffing" a box can detract from sound quality regardless of the lower Q, anyone herd anything about this? Option B, Question: how do you go about designing and building an aperiodic vent? is it a case of making a fibreglass/steel mesh sandwich, then mounting and sealing it over holes say on the underside of the enclosure? I also read somewhere a while ago that this is preferable to option A and even has some benefits like raising and flattening impedance? Cheers Stew
Diy Speakers |
#2 |
It varies with frequency and loading, but 1.2x is a realistic average. Here's some measured results of various densities in sealed and vented: http://www.integracaraudio.com/carau...ces/fiberfill/ and a brief write-up on stuffed vented: http://www.geocities.com/kreskovs/Box-1.html
Aperiodic alignments can be simmed with any program that allows you to adjust Ql (box frictional losses) and/or Qp (vent frictional losses). GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
| Aperiodic boxes with aperiodic TL's - an idea. | Shoog | Full Range | 0 | 22nd May 2009 05:03 PM |
| ciare ch 250 / aperiodic box | DimZ | Full Range | 0 | 30th October 2008 11:13 AM |
| Anyone use aperiodic vent for midbass? | xtremekustomz | Car Audio | 0 | 9th November 2006 03:56 AM |
| Aperiodic box for B200. Vent size and box shape? | ChuckT | Full Range | 11 | 15th October 2006 07:29 AM |
| Scan-Speak Aperiodic Vent? | Pete Mazz | Multi-Way | 2 | 6th January 2002 11:38 AM |
| Page generated in 0.08060 seconds (67.84% PHP - 32.16% MySQL) with 10 queries |
