So what's your current (or upcoming project)
Old 24th April 2002, 12:40 AM   #21
baby_huey0 is offline baby_huey0
baby_huey0's Avatar
Send a message via ICQ to baby_huey0
I doing something thats a mix of The WATT/Puppy, the Geers eVe II, and the Andromeda. They are in the build process right now, I hope to finish the Tweet/Mid section in the next two weeks. They I will have something to listen to other than crappy technics speakers till I finish the lower cabinets. All the drivers are Seas, using pretty much the same look as the Geers with some styling of the WATT. I will definitely post pics when I'm done!
huey
Old 24th April 2002, 02:38 AM   #22
JoeBob is offline JoeBob  Canada
JoeBob's Avatar
Helix, could you comment on those New Class-B amps? Did you like the sound? And what exactly makes it "New" to class-B?. I ordered the EW archive on CD, came today but I wasn't home. I'll give the article a read when I pick it up tomorrow, it sounds interesting for you've mentioned it before on this forum I do believe...
Old 24th April 2002, 06:24 AM   #23
pete is offline pete  Australia
Default projects
A bandpass under-the-desk sub for my nxt computer speakers made from 24" long x 6" dia pvc using UniBox300 & a 4" Jaycar screened mid/woofer. The sub is in use and it is good down to 45- odd hz + room gain.
A pair of vented 48ltr mtm using vifa p17wj-00 & vifa xt25tg-30 (that I could really use some help with the crossovers).
A vented spherical sub (baseball?) made from a total of 60 triangular veneered mdf pieces 28"dia with two 12" isobaric drivers for the ht
pete
Old 24th April 2002, 07:35 AM   #24
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Default Re: So many projects, so little time
I am actually working on a pr of aperiodic boxes for the Pioneer 8' FR. I will be adding a "nose-cone" piezo to fill in on the top ala the PHY-HP 12". I am at the finishing the cabinet stage but have been held back by unseasonably cold weather (gotta do it outside).
Next up will probably be a bipolar line for some of the FE103As i have, to slide in where my RS 40-1197 (aka FE103) BD-Pipes are now. And then TL cabinets to replace the aperiodic ones i have my dual-8s in now. And a proper amp for the pipes (either another SE EL84 or a Forced-symetry EL 84 PP). And the AKSAs for my woofers. And, and, and ...
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 24th April 2002, 07:51 AM   #25
Vivek is offline Vivek  India
I am currently working on a pair of two-way bookshelf speakers and the 60-100 W amp from ESP.
A sub will follow if the bass in the bookshelf speakers is not to my liking.
Old 24th April 2002, 10:16 AM   #26
Andy G is offline Andy G  Australia
Andy G's Avatar
Default 2 projects...
A) A 3-way Vifa pyramid, using P21wo, P13wh, D25ag. series x-o. front will be gloss black, sides jarrah stained Tassie oak, back matt black.
P21 is an ebs compartment tuned to 35Hz (if i remember rightly) P13 is in an open backed stuffed tube.
B) "Conehead" a 6ft tal tapered quarterwave pipe using a Peerless 850122 6.5" + Tangband "eyeball" tweeter.
Now Playing: Lavay Smith and her Red Hot Skittle Lickers
Old 24th April 2002, 06:01 PM   #27
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
So what's your current (or upcoming project) Send a message via AIM to Peter Daniel
Bass reflex enclosure made out of epoxy, Raven 2 tweeter and 2 different sizes Foacal mids. Separate crossover or maybe bi-amped.
Old 24th April 2002, 06:09 PM   #28
Some of you probably know what it looks like.
Old 24th April 2002, 06:18 PM   #29
jam is offline jam  United States
jam's Avatar
Peter,
Brings to mind a question? Where do you get all that free time, I need to get a job where you work. Seroiusly, keep up the good work.
Jam
Old 24th April 2002, 06:24 PM   #30
I usually work 6 month a year as an aircraft contractor. Soon my time would be over.
So what's your current (or upcoming project)Hide this!Advertise here!
Upcoming Vifa drivers DcibeL Multi-Way 48 27th January 2010 11:36 PM
My upcoming LM4780 design youyoung21147 Chip Amps 16 17th November 2005 08:31 PM
Upcoming LM3886 SMD board JJJ Chip Amps 8 6th November 2004 09:02 AM
New heatsinks for my upcoming Aleph 5 elizard Pass Labs 37 14th June 2003 08:43 PM
Upcoming DIY2002 Digi Everything Else 0 18th April 2002 03:42 AM
