What would you do with these 6 drivers?
Old 16th April 2018, 10:27 PM   #1
DaveFred is offline DaveFred  Canada
Default What would you do with these 6 drivers?
Ever see some drivers that look good and you cannot pass up because the price is right? Well, I bought these six drivers for $200.00 USD.
Two SB Acoustics SB29RDC-C000-4 Tweeters
SB29RDC-C000-4 :: SB Acoustics
and
Four Tymphany Peerless HDS Nomex Woofers 830869 Woofers
Driver Detail | Tymphany
I think the ideal use for them would be in a ported 2-1/2 cubic foot floor standing speaker in a 2.5 configuration, but I don't have the space for that.
So, I am thinking about a ported isobaric 2 way system in a ~0.65 cubic foot box,
or a sealed 2.5 way in a ~1 cubic foot box.
What would you make with these if you wanted a box ~ 1 cubic foot or less?
These will be used with a sub woofer.
Old 16th April 2018, 11:11 PM   #2
jrh0516 is offline jrh0516  United States
jrh0516's Avatar
Horn loaded tweeter, MT in 38 liters. Buy some more tweeters
John H
Old 16th April 2018, 11:30 PM   #3
5th element is offline 5th element  United Kingdom
5th element's Avatar
Add in an 8" waveguide.
You can see some stuff with the neo version of that tweeter Feb 5th on Zaphs blog
Zaph|Audio
Build a TMM, crossover at about 1700Hz for a decent directivity match. Preferably crossing as low as is possible, whilst maintaining a good directivity match to help the vertical off axis.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Now with website! www.5een.co.uk under construction.
Old 16th April 2018, 11:33 PM   #4
Looks like someone did something similar here...
pics of my 8"/1"+WG 2-way plus crossover - Techtalk Speaker Building, Audio, Video Discussion Forum
Old 17th April 2018, 03:28 AM   #5
TMM is offline TMM  Australia
Send a message via AIM to TMM
The SB29 worked pretty well in a Visaton WG148R 6.5" waveguide for me. The fitment is a little funky because the mouth of the wg is a little too small and the SB29 faceplate is not flat. I just put a foam gasket on the faceplate to seal it against the wg and it seemed to work well. Could cross at ~1.4kHz LR4. I suspect milling the waveguide down until the mouth is at the correct diameter may perform even better.
Old 17th April 2018, 04:04 AM   #6
eriksquires is offline eriksquires  United States
eriksquires's Avatar
Oh, these are really nice!
How about a 2.5 way? TMM ? or a D'Appolito ?
All of my successes and failures can be explained by my attempts at getting a girlfriend. All of them.
Old 17th April 2018, 04:14 AM   #7
Here's a similar woofer used with multiple different tweeters:
Peerless HDS PPB 830860
Old 17th April 2018, 05:16 AM   #8
Bill poster is offline Bill poster  Thailand
Bill poster's Avatar
I'd add mid's. Make a sonus faber type design
What would you do with these 6 drivers?Hide this!Advertise here!
F.s. Cheap New Sliver flute 8 inch drivers and other raw drivers and Equipment Mr Daniel Swap Meet 0 24th August 2015 12:35 AM
FS: Total clearout - bass drivers, compression drivers, amps. truecolour Swap Meet 7 23rd December 2012 08:14 PM
JBL comp drivers, Dayton Reference Sub drivers for auction NO RESERVE pkpickard Swap Meet 1 21st January 2009 03:19 AM
FS: x25 Vifa 5" Drivers + x2 Diamond Audio 5.6 Hex Eton Drivers omarmipi Swap Meet 0 19th November 2007 04:21 AM
Open-Baffle dipoles...a heresy to pair PA drivers w/ home drivers? thadman Multi-Way 7 11th November 2006 09:11 PM
