Rod Elliot's test box for impedance flattening - starting point?
Old 16th April 2018, 06:55 PM   #1
KVSV is offline KVSV  United Kingdom
Default Rod Elliot's test box for impedance flattening - starting point?
Started on my first two-way project (SB12PFC25-4 + SB19ST-C000-4 in a 7L vented box).
I just built Rod Elliot's "test box": Loudspeaker Test Box
As he describes it "No maths, no spreadsheets, just a quick frequency scan and twiddle a couple of knobs to get the values needed".
First I need something to generate a sweep. I found this tutorial by Claudio Negro (Claudio Negro's home page, how to project and test a loudspeaker using Speaker Workshop) which I guess I can follow not only to generate a sweep but also to capture impedance graph. Is it a good option or there is an easier one?
Second question is where to start with cap/resistance knobs. I think there are way too many combination for the process to be be "quick". Any suggestions for the initial settings for the knobs? Should I use some online calculator, and then twiddle a bit to see how it affects the curve?
Third question. Is it actually worth doing it? Can I just measure impedance curve and frequency response and then model zobel and crossover in XSim?
Oh, and one last question! Should I measure impedance in free air or in a box?. Basically should I build test box close to final dimensions before attempting to measure?
thanks
Vladimir
Old 16th April 2018, 07:46 PM   #2
eriksquires is offline eriksquires  United States
eriksquires's Avatar
Third question is most important.
No, not worth doing.
For T/S values, use free air. This is what you use for box design.
For impedance, you should design your crossover with the in-box measurements, but for tweeters and sealed midrange drivers this is essentially the same as free-air. This is part of what you will need for crossover design.
If you wish to buy, DATS or OmniMic+DATS is a great choice. Otherwise, you can use Room EQ Wizard with a home made jig to get the necessary measurements.
Best,
E
All of my successes and failures can be explained by my attempts at getting a girlfriend. All of them.
Old 16th April 2018, 07:58 PM   #3
Thank you Erik. I didn't realise REW can measure impedance. Will start building boxes and will try measuring impedance and frequency response with REW. Might also try to work out crossovers using AllenB tutorial as an alternative approach.
Old 17th April 2018, 04:05 AM   #4
More on REW and impedance:
Impedance Measurement
Rod Elliot's test box for impedance flattening - starting point?Hide this!Advertise here!
Flattening Impedance with dual woofers bconnelly Multi-Way 6 27th November 2015 05:23 PM
Newbie in need of basic help and a starting point 3putt2o Introductions 2 8th December 2012 08:49 AM
how bad a starting point is this? gafhenderson Full Range 17 16th March 2012 10:54 PM
Closed end TL experiments, impedance flattening Dr_EM Multi-Way 90 5th January 2011 04:14 PM
Is the KEL-84 a good Starting Point? Rarkov Tubes / Valves 16 17th November 2003 10:48 PM
