DE250 exit angle is 14.8°
I've been looking around the Internet for the exit angle of the B&C DE250 Compression driver and found 3 different numbers (12, 13, 14.6)
I decided to ask B&C and they stated that it was 14.8°.
Hope it helps!
I once also asked B&C and they sent me CAD drawing of the driver with the number 14,6. I guess this makes no difference, even 14 would be good enough. It's only interesting that two different numbers come from the manufacturer. I don't think they would change anything. Maybe they have actually measured it better :)
You should communicate the serial number of your particular DE250s.
In the case of older drivers, B&C Italy would pass this on to their technical department/distribution center in Germany.
If you send me a pm, I'll give you the direct email address.
B&C's level of service is, by a margin, the best I have come across.
