MLTL & port length
MLTL & port length
Old 16th April 2018, 08:03 AM   #1
samuelj is offline samuelj  United States
Default MLTL & port length
I m planning a MLTL with a 45cm long 10cm dia port tuned to 30Hz. Usually I see people using shorter ports, so I did not find anyone asking this question that I am about to. Does the length of the port contribute to the total length of the transmission line for calculation of quarter-wave resonance frequency?
45cm is significantly long and I plan to place the port (maybe slot) outside the TL.
Thanks.
Old 16th April 2018, 08:22 AM   #2
wonderfulaudio is offline wonderfulaudio  India
The port is a lumped mass and should not affect length atleast
Old 16th April 2018, 01:44 PM   #3
pkitt is offline pkitt  United States
Theoretically, in an ML-TL the system is tuned by two contributors, the 1/4-wavelength resonant frequency from the line's length and the port's dimensions. The length of the line will determine how much it contributes, and the port will make up the difference. For instance if you were building the most simplest form of an ML-TL, a floor-stander where the internal height is the line's length and that was, say, 40", its 1/4-wave resonant frequency would only be about 84 Hz, and if you were needing a system tuning frequency of 30 Hz, the port would be doing the most work. Now, if you had a longer line, say, 60", its 1/4-wave resonance would be ~56 Hz, allowing it to contribute a much larger part of the tuning and the port much less. Based on the length of your proposed port, it would seem there's very little contribution to the tuning from any internal dimension of the cabinet, or that the port's diameter is larger than absolutely necessary.
Paul
Thanks.
Old 16th April 2018, 02:48 PM   #4
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
What Paul said. I'd also add that a duct of that length will have issues with self-harmonics.
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Old 16th April 2018, 05:38 PM   #5
Just wanted to add that I've never had to use a port in an ML-TL having a diameter larger than 3", and most of them have had diameters of 2" or 2.5" with the system tuned between 25 and 35 Hz, resulting in predicted f3s in the low to mid-30s.
Paul
Old 17th April 2018, 01:54 AM   #6
Thank you very much for your help
I will consider port resonance in my design.
MLTL & port lengthHide this!Advertise here!
Port length nskii Multi-Way 10 13th July 2017 04:43 PM
help with port length.... torclausen Subwoofers 21 20th January 2014 04:18 PM
Slotted port length and aero port length. deebeez92 Subwoofers 3 26th March 2013 04:18 AM
port length tald Multi-Way 7 14th January 2010 01:26 PM
Help with port length please Bobhof Multi-Way 3 2nd May 2006 06:32 PM
