Miller & Kreisel S-1B satellite crossover update
Old 17th April 2018, 03:41 AM   #41
kenwood61 is offline kenwood61  United States
kenwood61's Avatar
You got me. It was the end of a busy work day and obviously I was talking out of the side of my head
Makes sense on the 5% tolerance. The stock caps were 10%, so that should make easier.
As a general rule, don't most really good brands tend to understate their values a little?
Old 17th April 2018, 03:42 AM   #42
eriksquires is offline eriksquires  United States
eriksquires's Avatar
Tolerances are tighter in film than electrolytic. Almost every film cap I ever bought, regardless of marking, was within 1%.
All of my successes and failures can be explained by my attempts at getting a girlfriend. All of them.
Old 17th April 2018, 04:18 PM   #43
kenwood61's Avatar
I think some of this is sinking in. I have a thread going over at AK, so now I have you and another guy giving me some good insight, and I should add, telling me the same thing, which is reassuring. So thanks!
What I'm now realizing is that the original design used 10% tolerance components (caps/resistors), which means I have a bigger range of values to choose from even if I limit myself to values within +/-5% ... since many of the MKP caps I'm looking at are typically 1%. So C1 can be +/-0.8uF for the 16uF cap. Am I'm getting this now?
Since the price of Audyn Q4 0.01uF, 400v MKP's at Parts Express are only $1.37, I could grab a batch of those ... unless I can find a smaller same value "bypass" cap. I need to look around since C1/C2 are tight spots and I don't know how close my bypass cap can be to the contour adjust pots or inductors.
Old 17th April 2018, 05:06 PM   #44
Yes.
Depends how fancy you want to get. Some makers measure every driver individually, and adjust the crossover parts independently.
I mean, just because they used 10% parts doesn't mean they didn't cherry pick. However, upgrading, giving yourself a 5% leeway in nominal part values is reasonable.
Best,
E
Old 17th April 2018, 05:25 PM   #45
kenwood61's Avatar
Thanks Erik!
I hope to have time to figure my parts list out today ... I'll post to see if I'm missing something, or ordering something I don't need. L8r
Old 18th April 2018, 08:56 PM   #46
kenwood61's Avatar
Well, didn't get parts yet. Waiting for some recommendation's from Parts Connexion. Hoping to hear back today or tomorrow. I'm curious to see if I can get all or most of my parts from them. I've always had good service and product from them.
Erik, have you tried the Vishay Roderstein MKP1837 0.01uF bypass caps? There are more than a few favorable reviews. They are squarish, rather than round, but if the leads are long enough to reach around to the "main" cap, I can see them working.
Cleaned the back side of one crossover board. You can eat off it now.
Old 18th April 2018, 11:24 PM   #47
Crhis at PC is fabulous.
Nope. Never tried them.
Best,
E
Old 19th April 2018, 12:26 AM   #48
electrafixion71 is offline electrafixion71  Canada
electrafixion71's Avatar
I updated a pair of M&K S-1B's a few years ago, including the crossovers . I used Mundorf electrolytics sourced from Parts Connection; these aren't exotic, but they were reasonably priced and came in the correct values. One of those terrible speaker wire pinch terminals was broken on mine, so I cut them out, and glued a piece of ABS in their place. I installed modern 5 way binding posts in the ABS, and squeezed a wire from them to the back of the PCB. The final result worked out well. I was never able to find a purpose for the second set of inputs on the speakers, so I never connected them at all.
Old 19th April 2018, 04:38 AM   #49
Nice work Elextra! How did they sound afterwards?
I've never heard the Mundorf electrolytics.
Old 19th April 2018, 02:38 PM   #50
Unfortunately the speakers weren't functional when I first acquired them, so I can't provide a before and after report on the sound of the recap. Each side had a bad mid, and someone had "tinkered" with one of the crossovers replacing caps with a combination of different electrolytics and film caps. I bought used mids off eBay, and restored the crossover caps to factory values based on a schematic posted elsewhere on this site. The sounded very good once I got them back together. I also had the matching sub which was 100% original, and matched very nicely.
One more thing that just came to mind...I had to cut down the length of the binding posts to get the crossover board back in place. It was a bit if a hassle, but those factory pinch terminals are so horrid it was worth the effort.
Miller & Kreisel S-1B satellite crossover updateHide this!Advertise here!
Miller and Kreisel subwoofer MX 700 tobywhite Swap Meet 0 20th March 2017 02:18 PM
miller&kreisel plate amp trouble SS4927 Class D 0 25th March 2014 04:39 AM
LF info - Miller & Kreisel speakers akoe Swap Meet 1 5th March 2011 03:45 PM
FS: Miller & Kreisel Woofers matevana Swap Meet 1 20th October 2010 05:49 PM
Miller & kreisel cnctooltek Multi-Way 1 4th November 2006 01:00 AM
