Miller & Kreisel S-1B satellite crossover update
Old 15th April 2018, 08:13 PM   #31
eriksquires is offline eriksquires  United States
eriksquires's Avatar
Also, you don't necessarily need to replace every resistor there around the switches. Truth is those are set and forget.
Personally, I would bypass the switch entirely, reducing the possibility of arcing and added resistance through a dirty switch. Later models used SPDT type switches instead.
Best,
E
All of my successes and failures can be explained by my attempts at getting a girlfriend. All of them.
Old 15th April 2018, 10:13 PM   #32
kenwood61 is offline kenwood61  United States
kenwood61's Avatar
I use a Hakko FX-888D with T18-D24 chisel tip.
I normally don't replace resistors when they are functioning, unless there is a sonic benefit, so if you are suggesting I just leave those alone, I can do that. It's not like I can't come in later to update those, but my plan is to do this once on these.
I appreciate your suggestion of bypassing the switch, but since there is a chance I will move these on down the road, I feel it's important to keep that functionality. Call me old fashioned.
So two last questions. Were you confirming that I need to remove the solder on those speaker terminals at the pcb to remove?
Do you have recommendations on C1/C2 ?
Thanks for your time and help!
Old 15th April 2018, 11:22 PM   #33
I am pretty sure yes, you need to remove the speaker terminal solder.
For the size, Mundorf MKP are really hard to beat. I prefer Clarity, but again, physical size is a limiting factor.
You could also try replacing with a bi-polar electrolytic, leaving the last uF or so film.
Best,
E
Old 16th April 2018, 01:31 AM   #34
kenwood61's Avatar
All the caps are bi-polar, but I'll look at the prices/sizes on Clarity and Mundorf.
I'm confused by your comment "leaving the last uF or so film" ... I assume you are referring to C5 which is 4uF ... but the "or so" part got me.
Old 16th April 2018, 05:45 AM   #35
Sorry, no.
I meant to put a non-polar electrolytic with a film in parallel whose sum is the necessary uF you need.
So, perhaps a 15uF NPE + 1 uF film. Saves money, and space.
Best,
E
Old 16th April 2018, 03:47 PM   #36
kenwood61's Avatar
Gotcha.
Thanks. I'll work up my parts list today and post.
Old 17th April 2018, 12:34 AM   #37
kenwood61's Avatar
I can't believe that none of the brand capacitors I'm looking at have any of the values I'm looking for. I guess speaker design made a change somewhere along the line where 4/8/16/18/32 ohm values were no longer used.
It sure is easier to work on amps
Old 17th April 2018, 01:21 AM   #38
Yeah, I wondered about that. Those are some odd values. Still, that's an advantage. YOu can find 15uF, and add 1uF in film to get 16, or add 3.3uF to get 18.3uF (close enough)
Old 17th April 2018, 01:55 AM   #39
kenwood61's Avatar
You just hit on a point I was going to ask about. Is there a variation to ohm rating that is acceptable, or universally agreed that it will not negatively effect sound quality? And if so, I assume that it's better to be "just over" the stock value as opposed to "just under". Sorry for all the questions, but this is helpful for me to learn.
I have been looking at a few different online shops and I may end up buying from two places, which I wanted to avoid paying shipping twice. Parts Express has some cheap Audyn Cap Q4 1.0uF 400V MKP for only $1.77 each
Audyn Cap Q4 1.0uF 400V MKP Metalized Polypropylene Foil Crossover Capacitor
... of course, they are almost three times the size of the stock value caps in there now, but if the leads are long enough, I might be able to set on top of NPE's and put wire insulation on the leads.
Old 17th April 2018, 03:20 AM   #40
Caps are in microfarads, not Ohms. Written with a mu ( like a little u ) and an F.
I try to get as close as I can, but look at the cap values. Usually there will be a tolerance, like 5%.
That tells you the caps are +- 5% and you can use that as a guide. Many like Audyn, just keep an eye on physical size!
Best,
E
Miller & Kreisel S-1B satellite crossover updateHide this!Advertise here!
Miller and Kreisel subwoofer MX 700 tobywhite Swap Meet 0 20th March 2017 02:18 PM
miller&kreisel plate amp trouble SS4927 Class D 0 25th March 2014 04:39 AM
LF info - Miller & Kreisel speakers akoe Swap Meet 1 5th March 2011 03:45 PM
FS: Miller & Kreisel Woofers matevana Swap Meet 1 20th October 2010 05:49 PM
Miller & kreisel cnctooltek Multi-Way 1 4th November 2006 01:00 AM
