Crossover frequency for transmission line
Old 16th April 2018, 08:42 PM   #21
phivates is offline phivates  United States
Time to do some reading on the basics of quarter wave enclosures
Old 16th April 2018, 08:49 PM   #22
Cliveinuk is offline Cliveinuk  United Kingdom
Sorry Paul
re read your post and got the 24:1 taper didnt understand it because it is so extreme a taper
with such a small vent at the end !! is that plausible most youtube versions I have seen are either straight line or a much smaller taper 1.5 to 1 etc
Old 16th April 2018, 08:52 PM   #23
never seen one with such an extreme taper and usually the driver is at the start of the line
Old 16th April 2018, 09:57 PM   #24
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Clive,
MDF is not a recommended build material. Use quality plywood. With a driver as large as the Morel intended, 15mm might do (it would if you had a pair loaded push-push). 18mm plywood would probably be recommended for a single driver.
24:1
Here is a sketch of what Paul specified. It would normally be folded once to create a useful package.
Crossover frequency for transmission line-pkitt-morel-uw-1058-tl-png
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 16th April 2018, 09:59 PM   #25
frugal-phile(tm)
planet10's Avatar
The taper is severe, but that makes it more compact. Paul is well known for his heavily tapered lines. Since the advent of proper TL-modelers, an end-loaded driver is rarely seen.
dave
Old 16th April 2018, 10:15 PM   #26
Dave , thank you for that , I guess I was expecting the end of the line opening to be bigger than that.
my question about material was more to do with the effect of one vs the other and how it played out on the baffle step
Old 16th April 2018, 10:22 PM   #27
frugal-phile(tm)
planet10's Avatar
Material choice does not affect baffle step. Enclosure shape and driver placement are the factors.
dave
Old 16th April 2018, 10:44 PM   #28
Dave (moderator)
how do I attach an image/photo to a post ( your insert image is asking for a URL
Old 16th April 2018, 10:47 PM   #29
pkitt is offline pkitt  United States
To any of you concerned about my use of "severe" tapers, I'd much prefer they to be called aggressive because there's nothing about the modeled or sonic results that's at all severe. I never use a taper less than 10:1, simply because of its attributes of making the line a lot shorter and, more important, smoothing out the ripples in the response like more stuffing would do but without sacrificing low-end output. I've used a taper ratio of 16:1 and 25:1 quite effectively in personal builds. The only way an aggressive taper can be problematic is if the air velocity in the end of the line becomes excessive and I always make sure that is not an issue (17 m/s or less) when the driver is driven to Xmax and a bit beyond at a frequency that is likely to be part of the musical content.
Paul
Old 16th April 2018, 10:51 PM   #30
frugal-phile(tm)
planet10's Avatar
You also have the choice of uploading a file from your computer.
dace
Crossover frequency for transmission lineHide this!Advertise here!
Validating LA transmission line box in Hornresp: how to simulate line stuffing? altie Multi-Way 23 12th April 2018 12:57 AM
Multiple driver transmission line "1.5" crossover mashaffer Multi-Way 14 26th December 2016 10:20 AM
Choosing the length/frequency of a transmission line nannoo Multi-Way 35 14th February 2014 11:12 PM
Help with converting sealed box line array loudspeaker to transmission line enclosure jb0194 Multi-Way 3 7th January 2012 05:08 AM
Crossover frequency selection for line array goldyrathore Multi-Way 5 13th June 2009 08:28 PM
