Has anyone tried these MMTMM configurations?
Old 14th April 2018, 07:04 PM   #31
Juhazi is online now Juhazi  Finland
Juhazi's Avatar
^Wouldn't it be easier to just use minimal diameter drivers per "way" to get smooth and wide dispersion?
Well then we encounter the distortion challenge... But if we discuss only normal home environment/sound levels, there should be no problems with that. Examples - Yamaha NS-5000, Magico, Avalon, PMC, Harbeth, etc. 3-way speakers with 3-5" midranges and dome tweeters.
AINOgradient speaker project
Old 15th April 2018, 11:18 PM   #32
hollowboy is offline hollowboy  Australia
Originally Posted by Juhazi View Post
The patent and measurements in it are just rubbish.
Rubbish how? Are you implying that the measurements are false / fabricated?
The 4-driver flower is acoustically like a single 15" [...] Sure it is different above 500Hz
Yes. This appears to be the point.
This edit signature thingy is seriously hard to find
Old 16th April 2018, 07:09 AM   #33
Juhazi's Avatar
^A quadruple (or any group of widerange transducers) has similar directivity as a single driver of same outer diameter. The patent application and controllees just didn't know that. Poor understanding of the topic! It should be impossible to get a patent to a law/ phenomenom that is just basic physics!
Old 16th April 2018, 07:46 AM   #34
I see what you mean. The patent is just a rotation of a basic array, so may not be sufficiently novel:
"Using this method, a typical speaker array may attain benefits disclosed herewith."
However:
"Embodiments of the present invention achieve this result by an advantageous arrangement of transducers."
The specific details of the "advantageous arrangement" seem to be the point of the patent.
To me, it is not immediately obvious how you would get the pattern shown in figure 22 rather than the pattern in figure 20. If literally nobody had produced or illustrated this benefit of skewing an array in this manner*, that implies it wasn't immediately obvious to anyone else, either.
Note that the patent is hella old, doesn't apply to DIY, and I'm not a lawyer, so I don't really have a horse in this race
*I believe a requirement of a patent is that it hasn't been made / described / illustrated publicly elsewhere
Old 16th April 2018, 08:18 AM   #35
Juhazi's Avatar
With a loudspeaker simulation software it is easy to test jos multiple driver groups behave. They were not so easily available 10 years ago.
Old 16th April 2018, 05:30 PM   #36
nc535 is offline nc535
There is a way to get multiple drivers to behave as a point source without beaming and lobing problems. For a clue, look at my signature
BTW, one of the drawings in the Synergy patent shows a relatively large number of drivers surrounding a central driver on a baffle. Basically, a baffle is a 180H x 180V horn. Its much easier to get the drivers close enough together when they are offset mounted on the sides of a less wide dispersion horn.
My Synergy Corner Horns and Bass Bins
http://www.diyaudio.com/forums/multi...bass-bins.html
Has anyone tried these MMTMM configurations?Hide this!Advertise here!
Idea for tall slim B3s design- MMTMM joe carrow Multi-Way 59 27th November 2009 10:11 PM
MMTMM Why not more designs? ultrakaz Multi-Way 10 4th October 2009 12:07 AM
Hi-Vi B3N MTM Towers and MMTMM Center jsalbre Multi-Way 13 25th July 2008 11:41 AM
Would this be MMTMM or WMTMW... elambert Multi-Way 3 23rd July 2005 03:08 AM
progress pic MMTMM based on HIVI B3N Tazz Multi-Way 1 18th July 2005 05:03 PM
