Old 12th April 2004, 06:50 PM   #1
Default Output abilities of different tweeters...
In the PA speakers I am making, I would like to use a driver for the high frequencies that is not a horn.
Generally speaking, what type of driver tends to have the most output capabilities, a dome, bullet, slot, or even a ribbon like the Apex Jr ribbon....
http://www.apexjr.com/speakerstuff.html
I assume that the surface area of the driver is the most important, but I don't know how some drivers act at high SPL's, especially ribbons.
I know that the horn will keep dispersion under control, but I would prefer to stay away from the horn sound (especially in the midrange) and find another way to control the dispersion.
Old 12th April 2004, 07:04 PM   #2
Its a fairly general rule that distortion is related to operating power
and consequently horn loaded tweeters have lower distortion when
operated in a PA due to their high senstivity and consequent after
padding low operating power.
Very hard to get away from in a PA.
Ribbons resemble fuses far too much, i.e. peak power is very
similar to continuous power due to low thermal "mass" to be
of reliable use in a PA.
sreten.
Difference between SE output transformer and push-pull output transformers hilbert_mostert Tubes / Valves 12 8th March 2009 05:10 PM
3C24 in a SE output stage - output transformer impedance recommendation !!! aldovan Tubes / Valves 15 6th September 2008 10:18 AM
Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 freddymac406 Tubes / Valves 3 21st April 2007 06:15 PM
Can An Output Transformer Change A Voltage Amp's Output Impedance From 0.1 To 47 Ohms kelticwizard Everything Else 11 25th March 2007 05:17 AM
I2S digital output in Marantz CD4000 and four TDA1541A with balance analog output iklari14 Digital Source 30 18th July 2003 12:57 PM
Page generated in 0.07207 seconds (67.97% PHP - 32.03% MySQL) with 10 queries
