#11 |
IMO to be serious for a moment :
1) Poor general design 2) Poor crossover design 3) Drivers used (though good 1&2 cannot fix bad 3) 4) Box type, tuning, size, etc 5) Box construction quality 6) Suitability for purpose sreten.
#12 |
And , of course, the taste of the designer...
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#13 | |
Speakerholic
I think you might want to narrow your question down a little bit so we have a chance to give you a serious answer. What is it you would like to know about the holy loudspeaker? Cal |
#14 |
Banned
most important for the sound quality is the quality and quantity if wine you drink while listening.
If you do a search you will find some postings by well known and respected persons in this board who will confirm this. The principle is: good wine, a bit: sound better a bit more: sound a bit much better and more and more and more, sound is outstanding, you are high, crank up volume. much more: you don´t find the player to change CD. bad wine: a bit: does it still sound good? bit more: crank up the volume. more: it does sound a little - metallic? distorted? and not load enough. more: fuzzy, somehow more: head aches too much: wake up next morning, clean up the mess. |
#15 |
hi
a driver cannot be defined by , to consider its t/s parameters , never actually suggests how it will play or the materials it may be constructed with , ofcourse if it was to be used by the police force - kevlar is very important but when it is to ultimately convert source to analougus sound , what are on line is its realism , accuracy , depth , tone / timbre , nature etc in hi fi in pro audio - directivity , effective spl , accuracy , decay etc it cannot be defined by a mechanical formula what has all this got to do with diy ? when one has to choose a drive unit or units for ones amp / speaker enclosure in mind etc what are the factors worth considering ? considering a purchase of a loudspeaker unit ts parameters defines this unit mechanically , through these mechanical parameters one can proceed to use / utilise the unit to its best , including efficiency , and is of utmost importance to its enclosure design enclosure but one has also paid for the materials used in the construction of the drive unit , this will decide its longetivity , compression at peak power , overall accuracy - not to mention the tonal quality or the nature of sound produced where am i heading , - the internal volume of a cone may be same as that made of ordinary hard pressed paper or for eg a kevlar woofer 1 set of compliance figures can be easily duplicated between a rubber surround cone / and a foam surround cone all the manufacturer needs to do is control the hardness factor of the rubber surround material (ie the rubber) and the density of the foam material _ of the foam surround with this surround material differance the sound quality of both the drive units will be entirely different - along with the materials used the construction process is of importance so is the x- max the voice coil inductance , the cooling efficiency distortion - can be reduced by a symmetrical field magnet structure , shorting rings for eddys , shorting rings built into the coil to limit the coil from leaving the magnetic gap during extreme excursions these important issues relating the drive unit is not reflected very much in the t/s matters where am i going ? i can copy a standard 100 $s subwoofer unit' s t/s parameter using ordinary components for eg a pressed paper instead of a non press one , same coil dia , wire winding etc but with a poor insulation and it will never play , last , sound as the original 100 $ s one this is of utmost importance to diy constructors , along with t/s parameters Reverting to important issues governing diy and speaker design 1 . The speaker matching with the amplifier , I can provide a double magnet (155 to 230 mm) subwoofer in a lambada extended pole underhung sfg topology magnet structure with a kapton voice coil with imported aluminum wire voice coil lengths in excess of 60 mm with a xmax of 25 mm at 4 ohms , a imported non-press paper rubber surround cone (which totally absorbs all mid + hi frequency due to the cone design) and if the user constructs the most powerful IC amp it will not match infact it won’t match a 150 w rms transistorized design using latest Toshiba ets transistors the reason – the magnet structure is over damped now if it was the crescendo mosfet amp then we are going somewhere , Two the type of the transducer , its power handling , has the voice coil size been increased blindly to increase power handling without magnetic efficiency and x – max in mind ? the type of cone used , pressed paper , semi press paper , non press paper , felted composite , reinforced ets ( this decides how the speaker will sound ) the motor structure , sfg (symmetrical field geometry magnet structure) , for full range and pro drivers if there are eddy current shorting rings , other shorting rings employed to extend frequency response , linearise impedance , improve transience the vc material and wire , the vc inductance – 2 layer , 4 layer , dual vc type etc the suspension system and compliance surround material , eg rubber then type natural or synthetic ets , the extent of the roll of the surround and its match with the spiders the construction – at the end all parts of a speaker is held together by adhesives , the quality of adhesives used / and the process of manufacturing , for eg if I repair a toy with a epoxy hardener type adhesive and do not allow for the correct drying time … at the end all manufacturers are increasing production speeds suranjan transducer design engineer ------------------------------------------------------------------------------- then a good driver ? hi this statement can be said as correct that : a power rating given to a driver , means that at all input levels of the driver rating within its specified limit , the driver : 1 ) should perform within the rating in long term use , robustness 2) should perform within very acceptable limits of distortion 3) and should show a certain limit of linearity in relation with the , actual accoustic power output increase to the input power supplied from the amps without compression the distortion is now adays mostly the deciding factor of the power rating including long term use Here it needs to be devided in two sections FIRST SECTION in a broad context distortion / you will find some speakers distorting _ much before the voice coil actually burns out for eg - considering a driver in which this takes place : a driver or if they are pro audio or drivers with simple pole vent cooling with the coils set in a tight magnetic gap - the coil can be on a paper former , oridinary wires used in the vc s the vc s temperature will not rise easily normally 60 deg max , at this time it will distort then this distortion is not from the vc temperature (though in most books vc temp is one of the main source of distortion , why ? read on ....) there are 3 basic types of non linearity in a transducer , these generate distortion , due to this distortion the voice coil heats up / at this moment no amount of cooling can help , the distortion effect from driver non linearities are such that it may lead to vc temp rise exponentially leading to vc burn out the non linearities are 1. non linearity in the suspension mechanism 2. non linearity in the motor sturucture 3. non linearity caused when a coil moves in a permanent magnet motor structure (this is bound to happen even if the above 2 non linearities are addressed well ) to check for these non linearities while purchasing drivers 1. suspension non linearity for the x - max of the driver you would like to purchase (or the one specified by the manufacturer) meaning you either know the x-max or have one in mind , then : step a push the driver cone downwards by that amount , it should go down linearly (the stiffness of the suspension increasing linearly) to the amount of the x-max step b pull the cone upwards towards you from beneath and it should come up to the specified x-max , again stiffness increasing linearly if this does not take place the driver will distort - unless the transducer manufacturer identifies specifically that such a non - linearity has been addressed , by making suitable compensations in the vc itself 2. motorstructure non linearity fringe fields exists at the magnetic gap - the motor structure should be - sfg a symmetrical field geometry _ topology therefore while purchasing a driver look if the motorstructure is - sfg or not since expenses goes up in a sfg structure it will be specifically mentioned mentioned by the driver manufacturer , to inform customers 3. Non linearity caused when a coil moves in a permanent magnet motor structure explaining this nature of non linearity is complex , anyone interested can see the sections on shorting rings in my thread what is important is that : - has this been addressed by the transducer manufacturer it is addressed by shorting rings placed in the motorstructure since this too involves expence , and a considerable slow down in the manufacturing process this too will be specified by the driver manufacturer , to inform customers - the above are the main sources of distortion that determines the safe operating power of a driver , and are not the only sources of driver distortion (other sources of distortion are eddys , bottoming to name a few) due to such complex stuff good driver manufacturers all over the world can be counted on finger tips ------------------------------------------------------------------------------------ SECOND SECTION in good drivers context good drivers are in which all the above criterias have been addressed then the rise in vc temperature over long time use / the cooling efficiency comes in , and mostly all speaker failures of reputated manufacturers result from vc burn out (as mentioned by Navin) mostly these limits are tested thoroughly and drivers tested to distruction and safe regions specified Suranjan Das Gupta Transducer Design Engineer |
#16 |
i have found driver malfunction due to negligence of owners to go in for a service contract when pro audio drivers are used eg - movie halls , discs
in home audio , sources of reputated driver burn outs are : a) amp malfunction and dc component generation in the drive signal or signal clipping speacially when high power speakers are used by under powered amps , many people do not even consider that a 35 w amp can damage a 100 w speaker system _ plain simple signal clipping can distroy well made drivers if you have an under powered amp please ask a sound engineer to determine the clipping levels of your amp and restrict from running at clipping levels (in high end audio amps from manufacturers like Nad and onwards this is built in as standard , in the circuitry , therefore the prices) b) or the suspension parts have outlived _ may be the owner ! Suranjan Das Gupta Transducer Design Engineer |
#17 |
Speakerholic
Hi Suranjan,
What a novel. I wonder if the original poster has any idea of what you just wrote? Thanks for the reading, Cal |
| What makes a voltage source sound good? | Onvinyl | Power Supplies | 28 | 7th August 2008 08:29 PM |
| What makes kef 105/2 sound so special | kifeinthesink | Multi-Way | 4 | 23rd December 2005 03:55 PM |
| With one makes more sound! | destroyer X | Solid State | 43 | 8th June 2004 12:11 PM |
| What makes the most sound improvement? | BlackDog | Chip Amps | 19 | 29th February 2004 08:56 PM |
| Page generated in 0.13755 seconds (87.05% PHP - 12.95% MySQL) with 10 queries |
