suspicious of paper cones
I've always been suspicious of paper:
1) I live in Ohio and we go from 0% humidity in late February to near 100% in early March. If size, stiffness or weight changes, it could be noticeable. Similar transitions occur as summer dries everything out, and then it gets we again in the fall.
2) Paper (in theory) degrades over time. I know most quality paper cones should outlive rubber surrounds, but at least with a metal or ceramic cone, it is either perfect or broken, not much middle ground. Paper could lose original stiffness or other performance, without an easy way of telling.
Are either of these reasons valid for avoiding paper?
I have 50 years old Philips 9710 still working as they should. I have 60 year old Goodman Axiette that work as well.
At least Toledo (Ohio) is nothing special compared to many parts of Europe.
Really dry indoor air during the winter can be cured by using a rotary heat exchanger instead plate heat exchanger.:D
