I own a pair of Fostex FW 305 woofers that are rated at about 95db/watt sensitivity-
https://www.google.com.au/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwiJtp2k7fTZAhUV5rwKHVetC_0QFggpMAA&url=https%3A%2F%2Fwww.madisoundspeakerstore.com%2Fapprox-12-woofers%2Ffostex-fw305-12-woofer%2F&usg=AOvVaw2u8p-TUNLdAhN8iFmZMj3o
I tried to make 2 way using these and a Heil AMT tweeter crossing at about 1000Hz but could not get it to sound right.I suspect the Fostex is really best used as a pure woofer below about 400Hz and not in a two way.
So I was wanting to match it with a similar sensitivity midrange .This Audax looks like it might do the job-
https://www.google.com.au/url?sa=t&...range-100db/&usg=AOvVaw1drXZi0-nY9yUJKvl4UZz5
It is rated at 100db/watt but if you look at the response it is more like 95db 500Hz to 4000Hz.
Which just leaves a similar sensitivity tweeter.Any suggestions for that?
I had in mind crossover points at around 400Hz and 4-5000Hz.
Any thoughts,suggestions or experience using these drivers and crosssover that might suit?
Trying to keep it 8 ohm and as simple as possible.
SB Satori tweeters happen to be 96db, quite rare for home audio dome tweeters.
SATORI TW29RN :: SB Acoustics
Do not blame FW 305, the problem is in the crossover.I own a pair of Fostex FW 305 woofers that are rated at about 95db/watt sensitivity-
Did you measure the drivers mounted in the loudspeaker enclosure? Which simulation software are you using?
From a quick review:
*Fostex FW 305 datasheet shows SPL ~93db. In-Room placement baffle step effects could reduce this to ~90db.
*WinISD simulation recommends, 2cuft ported Qtc=0.7 alignment -F3=46Hz
Suggestion for a reasonable cost 90-92db SPL tweeter-mid with Zmin~4ohms:
SB_Acoustics: SB26STCN-C000-4 92.5db sensitivity ($33)
Satori: MR16P-4 92db sensitivity ($148)
This combination would build a very musical speaker in a modest size 2.5cuft ported box. Room bass gain can strengthen the -F3=46Hz.
The FW305 has a Xmax=4.8mm, and this will limit bass output if you decide to build a 1.7cuft sealed alignment with DSP Linkwitz Transform equalization to reach -F3=30Hz bass.
- Medium/High Efficiency 3 way concept.
