Crossover in a very limited space...
Old 15th March 2018, 07:44 PM   #11
00940 is offline 00940  Belgium
00940's Avatar
I'm a bit uneasy discussing the crossover first because it is a kit and second because I'm really a complete newbie at crossovers.
A quick sim shows that the filter drops the level by 5 to 6db over most of the passband.
Btw, that little driver is really heavy
All that is excessive is insignificant. Talleyrand
Old 15th March 2018, 07:53 PM   #12
ICG is offline ICG  Germany
ICG's Avatar
Originally Posted by andy2 View Post
Just a side note, does any know what's the typical volume in liter of the xover for a 2way monitor?
That depends pretty much on the monitor. Most are below 0,1l, so absolutely neglectable.
I had a Déjà Moo - I've seen that BS before!
Old 15th March 2018, 07:58 PM   #13
Lojzek is offline Lojzek  Croatia
Lojzek's Avatar
I think I know now what's wrong with it. In the product pdf of micro speaker the impedance graph shows the lowest Z at about 7 ohms and that can only be with an 8 ohm driver, although the data for the driver says it's Peerless SLS 85 S25 CP04-4, which is probably a typo, as it should have been written CP04-08. Then sensitivity and impedance do match up for the 8 ohm unit.
edit: I am not interested in you disclosing the filter parts values, I would not have any use of it. My curiosity is whether a driver being used in this kit is a 4 or an 8 ohm version, which you can check easily. Thank you!
A good dialogue makes you feel like a changed person, not like you have won or lost the competition.
Old 15th March 2018, 08:21 PM   #14
00940's Avatar
It really comes with a 4 ohms driver. I'm pretty sure it was discussed somewhere on hifi-forum.de but I can't find the thread anymore.
Old 15th March 2018, 08:54 PM   #15
Lojzek's Avatar
Then the dcr of the inductors must have contributed to the increased impedance profile and lowered the sensitivity.
Old 17th March 2018, 09:14 AM   #16
00940's Avatar
There's indeed about 1R3 worth of dcr in line with the woofer. It's a sealed GHP design btw (Subwooferabstimmung mit Kondensator und Widerstand).
It's coming along nicely. I've got the feeling that the smaller the speaker, the harder it is to build. There's really no room for tolerance.
Old 16th April 2018, 05:19 PM   #17
00940's Avatar
It's slowly coming together. Veneering is done, the crossover section for the tweeter is installed (inside the main box). I still have to install the crossover section for the wooder (inside the black support) and wire the drivers.
I'll then be able to quickly test everything before gluing the front plates and put some tung oil on the veneer.
I'm really amazed that they suggest to fit everything inside the speaker... that'd be quite a feat.
Old 16th April 2018, 05:27 PM   #18
adason is offline adason  United States
adason's Avatar
you need thicker cables...
Old 16th April 2018, 06:07 PM   #19
eriksquires is offline eriksquires  United States
eriksquires's Avatar
Very nice!
You might want to use Mills in the future, as they are very good, and very small for the wattage.
Best,
E
All of my successes and failures can be explained by my attempts at getting a girlfriend. All of them.
Old 24th April 2018, 02:00 PM   #20
00940's Avatar
Getting there...Awaiting final coating.
Crossover in a very limited space...Hide this!Advertise here!
Best Enclosure Options for LFE in a Limited Space? ddhank Subwoofers 4 13th November 2016 03:26 PM
left/center/right in limited space BarryV Multi-Way 2 11th February 2009 07:30 PM
limited IC for DIY, what are you looking for eledora Parts 0 22nd February 2008 08:42 AM
need a SPL box for a limited amount of space de57roy Car Audio 3 24th August 2007 05:38 PM
ar limited 3 tze-hao yen Multi-Way 0 25th August 2004 02:52 AM
