Crossover design problems/suggestions
Old 21st March 2018, 02:34 PM   #41
EarlK is offline EarlK  Canada
Originally Posted by sese317j View Post
I already checked, it goes down to like 5 Ohms from 18-20khz, but the amp is 6 Ohm stable, so i dont think that is an issue.
I think Bills concern is focused on the impedance above 20K, up in the ultra-sonics.
Unfortunately, XSim doesn't go past 20K so one is left to ones own life-experience for predicting the trend lines.
Old 21st March 2018, 03:14 PM   #42
Something to realize is that traditional Passive layouts are generally safer ( impedance wise ) than the somewhat esoteric layouts such as what are now being most recently talked about here in this thread.
- You might want to spend some time redesigning according to those safer principals ( as seen in the first handful of posts ).
OTOH, the following is also esoteric ( but I've added some resistance in various places to increase the overall impedance level ).
- this was done using a pair of your older files ( 1.45" was used as the offset > so I don't know how accurate this will translate ultimately ).
It's presented more as an example on how to make some FR compromises ( while increasing overall impedance ).
I can't see beyond 20K and can only guess that the impedance at 50K ( or even 100K ) is still alright ( & stable ) for a typical PA amp.
Crossover design problems/suggestions-mo-em-1-45in_hi-lo-png
Old 23rd March 2018, 12:43 AM   #43
XMechanik is offline XMechanik  Poland
Another circuit to have look at. The circuit was designed based on the last measurements and delay findings (post#37). The biggest difference can be seen around 4kHz. The original circuit trace (green) shows a 5dB raise which likely comes from breakups of the Monacor driver. New midwofer filter has 10dB more attenuation @4kHz and this area is left to be served by the tweeter.
The circuit doesn't look simple but don't be cheated with the number of coils, wchih is 5, as 2 of them are microscopic and cost little more than resistors.
XMachina page thread
Crossover design problems/suggestionsHide this!Advertise here!
XO3: The 1/2/3-way Active Crossover/filter PCB. Design suggestions welcome! s3tup Analog Line Level 52 5th October 2011 03:27 PM
<AUS> B3S active crossover design - Value woofer suggestions? TheSeekerr Multi-Way 0 25th August 2008 12:46 PM
Suggestions on OB problems maoumaou Multi-Way 13 29th February 2008 02:35 AM
Suggestions on my crossover design? JoeyDD Multi-Way 11 11th December 2005 02:05 PM
Amp problems, suggestions needed :( fedx Solid State 3 21st October 2005 03:38 AM
