1970's TL remake help
Old 11th April 2018, 10:38 AM   #31
webby is offline webby  United Kingdom
Thanks Dave, I need to work with what I have if possible.
I have these inductors available;
0.25mH x 4
0.6mh x 2
1.5mH x 2
3.4mH x 2
6mH x 2
playing with a few online calculator, I came to this;
3rd Order (18 dB per Octave)
2100Hz, 6 Ohm tweeter
C1=8.42 F
C2=25.26 F
L1=0.34 mH I have already;
or
2900Hz
C1=6.1 F
C2=18.29 F
L1=0.25 mH I have already
I think I will start with the 2900Hz, does this sound reasonable?
Should be able to make up cap values.
Time to warm up the iron!
Old 11th April 2018, 04:45 PM   #32
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
On-line calculator will not likely be very accurate.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 11th April 2018, 08:22 PM   #33
Oh, I cobbled the 2900Hz values together. Not plugged them in yet.
What should I do to calculate the crossover?
Old 11th April 2018, 08:32 PM   #34
frugal-phile(tm)
planet10's Avatar
To do it proper one measures and uses an XO sim application, but there is a long thread here on XO development with no tools.
dave
Old 12th April 2018, 11:41 AM   #35
Borus is offline Borus  United States
Default you can try this
Real world crossover being used today with same tweeter and 6.5 Vifa midbass in a small closed box sound was surprisingly good. Crossover at aprox 2700Hz
"Ya but what does he know anyhow"
Old 23rd April 2018, 04:05 PM   #36
Hi All,
Had a few issues getting them up and running.
Still need to spray the inside of theTL port as you can see, pleased with the baffle mod.
I setup the basic crossovers on the minidsp and tweeter, used the TC9's to check the amp outputs were putting out the right frequencies so that nothing was blown.
Turns out one of the Tweeter was faulty, I managed to re solder the fine wires that had broken, it worked!
My Initial observation is that the tweeter output will need padding down a bit.
So I'm ready to break out the UMIK and REW.
Some suggestions on what and how to measure would be useful?
Ian
1970's TL remake helpHide this!Advertise here!
Stella light remake over to my own design? Mr Daniel Full Range 4 1st November 2015 11:36 PM
Totem Wind remake picowallspeaker Multi-Way 0 24th November 2011 10:49 PM
Vers 2x-Next remake bl3nd3r Full Range 3 12th June 2009 07:19 PM
Remake of my DoZ almost completed [pics] starbase218 Solid State 19 10th December 2006 07:47 PM
Avid 102 project (remake) hernja01 Multi-Way 4 6th February 2006 04:58 PM
