1970's TL remake help
Old 13th March 2018, 08:19 PM   #21
Fernando R is offline Fernando R  United States
I agree with Linesource and System 7 regarding the mid. Keep it 5". It is not so much a loudness issue but small drivers tend to sound constricted and undynamic. when crossed over too low. I would probably look for a Seas MCA15. A good alternative may be the poly SB15MFC. I had some experience with the old KEF B139. You don't want to take that driver any higher than 350-400 Hz. There are some large breakup modes not too far above that.
He uses numbers and statistics like a drunk uses a lamp post; for support rather than illumination.
Old 13th March 2018, 08:52 PM   #22
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
I have in the past suggested changing systems like this to a WAW… add a FF85wk or Alpair 5.2 (or if you want larger an A7.3/6.2) and bi-amp with a 250-350 Hz XO.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 14th March 2018, 12:53 AM   #23
phivates is offline phivates  United States
Dave would you call the bass enclosure a Daline?
Old 14th March 2018, 01:05 AM   #24
frugal-phile(tm)
planet10's Avatar
A variation of... a big initial chamber, then a skinny line.
These are the original articles.
http://www.p10hifi.net/TLS/downloads/Pro9TL-1.pdf
http://www.p10hifi.net/TLS/downloads/Pro9TL-Mk2.pdf
From what we know now i suspect that the TL part would be closer to optimum with the B139 on the "back".
dave
Old 14th March 2018, 01:11 AM   #25
Whoa - that's what I thought. Dumb luck right there. The original design could have vented below the B110. Wonder what they were thinking?
Old 14th March 2018, 01:27 AM   #26
frugal-phile(tm)
planet10's Avatar
The original design had the B110, and a midrange enclosure which the line went around... V2 uses a Peerless K040 wih its own cup/enclocure so th emid chamber could be ditched.
dave
Old 10th April 2018, 08:08 PM   #27
webby is offline webby  United Kingdom
Hi All,
Been too busy to post, but here is an update with photos.
I have taken on board your comments and decided to keep it simple, I am going to use the B139 and B110 and use the Vifa tweeter as the cut out is similar on the existing baffle.
Mini DSP for bass and mids. The reason I'm ditching the existing crossovers is that they were never designed for these cabinets, they are Cambridge Audio R50 4 way.
Originally Posted by chrisb View Post
Unless the crossovers or any of the drivers are trashed, I'd be inclined to keep as close to stock as possible, and if you want to flush the baffle, simply add additional batten /spacers, refurbish the baffle with a skim coat of bondo filler and re-paint, and maybe a new grille?
Cutting an all new front baffle by hand will be rather a lot of work - particularly for the B139.
So far I have repaired the baffles, loads of filler, epoxy and sanding!
They are solid and the drivers fit flush and airtight.
I have made spacers to make the baffles flush with the cabinet front edges and cross braces really tight, they make a surprising difference to the rigidity of the cabinets.
Sprayed the baffles, no photos yet.....
Just wiring up the drivers and getting ready to listen, but can you suggest a few starting points please.
Crossover ideas / frequencies for the B139 and B110 using mini DSP;
Crossover for the Vifa D25AG-05-06, Can I use just a cap? Any Ideas for a starting value?
My plan is to start without stuffing the cab or mid enclosure, measure with REW to get started and report back;
Please do suggest any thought on how to proceed.
Many thanks
Ian
Old 11th April 2018, 12:19 AM   #28
frugal-phile(tm)
planet10's Avatar
For the B110/B139 somewhere between 250 & 300 hz. I have found the TLS80 to hav ebaffle step starting at about 220Hz (so 200 Hz XO starting point) but these are narrower to higher will be needed. B139 has nasty resonances near 1kHz so you want them to be way down by then.
The B110 bextrene has some ugly stuff up high so it will likely need a low pass. I donít know how low the VIFA can be taken, but iíd suggest 2.5-3k as a starting point. That low you probably canít get away with 1st order.
dave
Old 11th April 2018, 08:48 AM   #29
Thank you Dave, just what I was looking for.
What frequency should I set the low pass for the B110?
Here are the Vifa specs;
Nominal impedance [ohm] 6
Voice coil resistance [ohm] 4.6
Nominal power [W] 100
Short term max power [W] -
Long term max power [W] -
Operating power [W] 4
Sensitivity [dB] 91
Frequency range [kHz] 2.5-35
Free air resonance [Hz] 1500
Voice coil diameter [mm] 25
Voice coil height [mm] 1.6
Air gap height [mm] 2
Voice coil inductance [mH] -
Eff. diaphragm Area [cm≤] 7.1
Moving mass [g] 0.3
Magnet weight [g]/[oz] 240/8.5
Force factor [Bl] 3.5
VAS [l] -
Qms -
Qes -
Qts -
I have some 10uF caps on hand, If I calculate correctly, will give a crossover frequency of 2500Hz, is that right?
Ian
Old 11th April 2018, 09:04 AM   #30
frugal-phile(tm)
planet10's Avatar
I gave up on dome tweeters a long time ago, and have no experience designing XOs for them. The only spec that really drives the XO point would be the Fs + the response curve. I’d guess one might be pushing them at 3k 2nd order.
Myself, i’d use an FF85wk or Alpair 5.2/6.2 or even 7.3 to replace the B110 and not use a tweeter at all.
dave
1970's TL remake helpHide this!Advertise here!
Stella light remake over to my own design? Mr Daniel Full Range 4 1st November 2015 11:36 PM
Totem Wind remake ÄÄ picowallspeaker Multi-Way 0 24th November 2011 10:49 PM
Vers 2x-Next remake bl3nd3r Full Range 3 12th June 2009 07:19 PM
Remake of my DoZ almost completed [pics] starbase218 Solid State 19 10th December 2006 07:47 PM
Avid 102 project (remake) hernja01 Multi-Way 4 6th February 2006 04:58 PM
