Thought i might share my latest project. Its a open baffle design using the Senon driver found at http://spectrumaudio.de in Germany. Some might notice the striking resemblence to Bastanis "Prometheus" and yes, its the same. Only difference is that i use 19 mm MDF instead. No calculation preeceded this project. I just though it might be fun to build something 🙂 Hopefully it wont sound too bad....
Next on the agenda is cutting the holes for the drivers. Also, i´m thinking of using a TangBand tweeter for the top end. Got two 28-847S that might be suitable.
Has anyone else on this forum bought these drivers ? It might be interresting to swap hints and experience about them.
Happy DIY:ing 😀 Regards // Mattias - Sweden
The progress is slow but steady. Both baffles are done 🙂
Ok. Both speakers are completed. Initial trail run revealed....well, not so great sound. The lack of higher frequenzies is wery prominent. They really do need aid from a tweeter. Also, in this perticular OB the sound is "jar" like ( for lack of a better word ). I will try to add some stuffing to see if the sound improves.
For the second listening i added a Apex Jr ribbon. Much better. The design has some potential so i will keep on tweaking.
Next on the agenda. A real crossover. Going for 6 db to begin with. Stuffing och some bracing of the baffle. And most important. The Senons need to be played a bit to loosen up.
Regards // Mattias S
454Casull: Yes indeed it has. However i´m not bound by that perticular driver since i´ve got some TangBand and some old peerless tweeters to play with. Trail & error is kinda fun. Aint it ? 😉
