Rare Snell Type 1 - Broken Tweeter
Old 13th February 2018, 08:25 PM   #11
phivates is online now phivates  United States
The Audax domes were either 1" (25mm) or 1.34" which is why I guessed Dynaudio - but those have three not four fasteners holder them together. Certainly Audax was everywhere back then. Models on the larger ones were HD13D34E or H. Your face plate looks like the 12x9 version of the ubiquitous HD100D25.
Old 13th February 2018, 08:33 PM   #12
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
My thots exactly.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 13th February 2018, 08:33 PM   #13
Boden is offline Boden  Netherlands
Does not look like Audax HD12x9, which tweeter did have 45 degree corners, not rounded like the picture shows. Polepiece also looks very different. I put my money on Peerless.
Old 13th February 2018, 08:49 PM   #14
Like a SK010 without the recess...well, it is what it is, which is broken.
Old 13th February 2018, 11:16 PM   #15
lt_texan is offline lt_texan  United States
So, maybe best to box 'em up and ship 'em out for repair.
Old 13th February 2018, 11:33 PM   #16
Yep...or sort through a thousand choices of current offerings
Old 11th March 2018, 04:00 PM   #17
Well....
Speaker Exchange delivered my tweeters back to me.
Basically, I understood that they were going to use the Snell tweeters faceplate and mount new tweeters on them.
What they did was make a new plastic faceplate with a hole in it and mounted a Morel MDT12 on top of the faceplate.
This doesn't really work because the ramp on the speakers fit right up the to faceplate with a notch cut out to clear the dome.
I thought about asking for a refund and returning the tweeters, but I really couldn't find any tweeter to use as a replacement. The 1 1/8" tweeters I could find had larger magnets that would not fit in the opening.
So, I thought, what the heck, what can I do.
So I removed the glued in Morel and cut out a tapered rectangular hole in the new faceplate. I tapered the Morel mounting plate, dropped it in and glued it flush.
The ramps fit now.
So far, the tweeters sound a bit harsh. Hopefully they will break in. The sound level seems fine - a bit on the bright side (it's a Snell - duh!)
These will do for now.
If I must make a change, I'll toy with an Audax TW025A1-12X9. It's a 1" and probably won't be great with the 10" woofer, but the magnet is a good fit.
Rare Snell Type 1 - Broken TweeterHide this!Advertise here!
Snell Type 1 Speaker: Tweeter Replacement/Repair dukenishi Parts 1 12th February 2018 08:26 PM
Snell Type Aii mr2racer Multi-Way 11 19th June 2014 01:57 PM
Snell type EII/III Hylle Multi-Way 5 6th July 2012 07:14 PM
Snell Type 1's lt_texan Multi-Way 7 8th July 2009 02:55 AM
Snell type D Skorpio Multi-Way 0 2nd September 2006 06:10 PM
