Old 8th April 2004, 10:08 AM   #1
tiagor is offline tiagor  Portugal
Default Need a suggestion for midrange
.. as neutral as possible, to be crossed at 500-5000, 90db efficiency or better, for a sealed enclosure.
Thanks,
Tiago
Old 8th April 2004, 11:06 AM   #2
http://www.d-s-t.com/vifa/data/p13mh-00-08a.htm
At its price this classic is hard to beat.
sreten.
Old 8th April 2004, 12:01 PM   #3
Send a message via Yahoo to ozynigma
http://www1.jaycar.com.au/productVie...Max=&SUBCATID=
These are going cheap in Australia. $125 a pair.
Can't vouch for them personally perhaps another member can.
Old 8th April 2004, 12:03 PM   #4
woops thats A$125, about $80-90US
Old 8th April 2004, 12:20 PM   #5
From what I observe this is the impression I get
level 1: Dayton, generic brands
level 2: Audax/Morel/Focal standard/Scan Speak
level 3: the specific vifa model sreten mentioned
level 4: Focal Wcone/audiom series
level 5: Seas Excel
level 6: Accuton 2" dome
level 7: Skaaning Flex Units
level 8: ATC 3" middome
other option is PHL, which i cant comment on.
The implementation is important, a genious speaker builder can make a speaker using cheap drivers sound as good as speakers with expensive drivers.
Old 8th April 2004, 01:58 PM   #6
Thank you for your responses.
sreten: Do you have an experience with the driver you recommended in a sealed enclosure?
tech.nockout: what dayton driver you had in mind? With a quick browsing I found a midrange 2"dome?!? I wonder how that sounds?
The question here is finding a driver that sounds good and as less coloured as possible in a sealed enclosure. As you probably have noticed, it is a 3way speaker.
I happen to like kevlar drivers for midrange, though I can't seem to find any with an efficiency in the order of 90db..
Tiago
Old 8th April 2004, 03:13 PM   #7
the dome, use it only if your budget is really tight or when your copying the Lyra project.
You should always go for the Vifa sreten mentioned if you can afford it.
need suggestion about MC pre-pre inertial Tubes / Valves 41 23rd March 2009 05:52 PM
Suggestion of a Midrange drivers bng Multi-Way 17 4th January 2009 04:03 AM
Midrange Suggestion bjackson Multi-Way 2 13th November 2005 08:38 PM
any suggestion is welcome! pamaz Pass Labs 6 5th March 2004 10:11 AM
Midrange suggestion... Nappylady Multi-Way 29 3rd May 2003 04:49 PM
Page generated in 0.08016 seconds (78.17% PHP - 21.83% MySQL) with 10 queries
