Use an av receiver's zone 2 feature as active crossover?
Old 14th February 2018, 07:18 PM   #11
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
You will need to either need to measure them or just experiment.
What kind of enclosure were they in in the TV?
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 15th February 2018, 07:47 AM   #12
rjbell is offline rjbell  United Kingdom
dave
I have an old Ferguson radiogram in my lounge it does not work its just a piece of furniture. I have linked up the drivers to a amp and they work but sound terrible. I suspect its down to the cabinet which is awful. Just a bit of flappy fiberboard and the rear and no internal dampening. Could I built a MDF cabinet within a cabinet?
Old 15th February 2018, 08:45 PM   #13
frugal-phile(tm)
planet10's Avatar
It sounds like the driver is mounted OB. If they actually chose a driver suited to OB, that may be the best way to use it. If you want to keep it in the radiogram just do a new baffle to replace the fibreboard. But part of the problem could be the radiogram around it.
It could also just be a poor driver.
MDF is not the best material to use.
dave
Old 16th February 2018, 08:07 AM   #14
dave
Yes, i might just give it a miss then. The is an audio exhibition locally at the end of the month. Mark Audio are there i might go and take a listen. If I like them i'll buy some drivers. There seem to be a few cabinet designs around for them and there baffle step compensation seems to be one of the easiest options for a first build?
Use an av receiver's zone 2 feature as active crossover?Hide this!Advertise here!
feature requests wanted for Active Crossover Designer tools v3.0 CharlieLaub Software Tools 17 29th June 2015 04:15 PM
Sell:MZC-88 WHOLE HOUSE MULTI-ZONE RECEIVER W/KEY-PADS hdmi Swap Meet 2 16th December 2009 11:12 PM
Active 3 way cross over kit. georgehifi Solid State 40 28th August 2006 06:56 AM
