Technics  SB-10 Crossover Questions
Old 9th February 2018, 09:03 PM   #31
TechnicsSB10fan is offline TechnicsSB10fan
TechnicsSB10fan's Avatar
OK now all that is left is to decide on what make and model cap, strange that all the threads I come across on make and model are about 10 years ago why is that.
I will keep looking. Need to get this happening.
Thanks for the help
Old 10th February 2018, 02:26 AM   #32
I have settled on the Mundorf evo oil .47uF and Mundorf m-lytic bi polar 330uFs sick of looking can get them here in this country, and is more then enough $.
Also considering some of those Russian Teflons to run as a bypass on the
tweeters 4 for ~ $20 might be worth a try any one tried them?
Old 10th February 2018, 07:43 AM   #33
Mooly's Avatar
I can't advise you on those parts I'm afraid as I would look for good commercial grade items at a fair price point
Old 10th February 2018, 08:24 AM   #34
I don`t think you could do much better price wise than Russian teflons.
Military Grade
Old 10th February 2018, 11:50 AM   #35
ICG is offline ICG  Germany
ICG's Avatar
Originally Posted by TechnicsSB10fan View Post
Military Grade
'Military Grade' usually mainly just means they are (mechanically) rugged. And what MG exactly means, differs from country to country.
And where would one be able to purchase these?
I had a Déjà Moo - I've seen that BS before!
Old 10th February 2018, 12:17 PM   #36
SOVCOM | eBay Stores
Do a search on ditaudio.com, others have already tried them.
Old 10th February 2018, 01:38 PM   #37
ICG's Avatar
At first I thought the prices aren't particularily cheap but then I noticed I just overlooked these aren't single pieces, that are bundle packages. These caps are (with postage included) around 1/5 of the cheapest foil caps I ordered so far. I'm just not particularily fond of the cyan colour some of these have.
I did not doubt the quality. It is popular to point fingers to russia and ridicule them. However, russia is known for excellent optics, rockets, planes and other technologies. And I am convinced nowadays you can produce high quality products all over the world. You are endorsing it and there is no reason to doubt your judgement. They produce good quality tubes too, I already bought some russian things like VU-meters, lenses and other stuff, so why not buying caps there and try it? I will likely try it and order the next caps I need from them. Thanks for the information.
Old 11th February 2018, 05:44 AM   #38
Oppps lots like I may have stepped on some toes here. My most sincere apologies.
I thank every one for their input, I have learn`t a lot, in my short time here.
Best regards
TechnicsSB10fan
Old 11th February 2018, 08:23 AM   #39
Mooly's Avatar
Not at all
Everyone has their own ideas and opinions and you see a good mix of that on the forums.
Old 11th February 2018, 10:00 AM   #40
ICG's Avatar
If you were referring to me (because mine was the only reply after your last), I'm not offended either. I just wanted to point out two things which I felt I had to justify:
  1. Military grade does not say anything unless you know the specifications and use. I mean, believe it or not, there are military grade leafblowers. What was the main requirement? They had to be used at 220/240V and aswell at 110V.
  2. In case you thought I was mocking somewhat, I wanted to make clear I have none prejudgements towards russian products (or from other countries) whatsoever.
Technics  SB-10 Crossover QuestionsHide this!Advertise here!
Technics SB6000a... Crossover schematic? mortron Multi-Way 2 19th May 2013 07:51 PM
Technics SU-V7 - some questions. ashleycox Solid State 9 6th October 2012 06:47 PM
Technics SP-10MKII service and maintenance questions HP8903B Analogue Source 7 24th May 2012 06:59 AM
Technics SL-1700 MK1 questions - value and replacement parts arjscott Analogue Source 2 19th March 2007 11:44 PM
Technics SU-X101 amp schematic wanted, and other questions falcott Solid State 4 22nd January 2005 08:12 AM
