Seas 27TBFC/G vs 27TDFC/G
Old 9th February 2018, 09:34 PM   #41
5th element is offline 5th element  United Kingdom
5th element's Avatar
If you want to do distortion measurements I would recommend you grab ARTA/STEPS and use that instead. If your amplifier and sound card output are flat in amplitude then the two channel measurement isn't really necessary.
Before, when you spoke of clipping, I am guessing that you were referring to the channel that measures the amplifiers output hitting its limits. While you could change the values on the resistor divider, to allow for larger amplifier output voltages, the easiest thing to do is simple go with a single channel measurement.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Now with website! www.5een.co.uk under construction.
Old 10th February 2018, 09:16 AM   #42
Dave Bullet is offline Dave Bullet  New Zealand
For those that still give a damn... here's a 27tbfcg 100 to 10000 plot at 0.5v level - no crossover
Old 10th February 2018, 09:17 AM   #43
And here's the 27tdfcg
Old 10th February 2018, 09:18 AM   #44
Both the above graphs are 1-5% distortion with 0.5% y axis grid markers.
Old 10th February 2018, 09:21 AM   #45
Thanks for that. I've downloaded Room EQ Wizard which seems to do a good job. I'll read the manual and see how I need to change my setup to work with it. I think ARTA requires licensing?
Maybe I'm just about ready to pull the xover trigger and buy the damn parts and just assemble and test in the mule. I am about to do a roundover as my final test, and re-measure with the 27TDFCG in place. That will confirm my measurements (on axis) plus some off axis ones.
I've managed to come up with some 1kHZ+ voicing options which maintain phase coherence which I will buy parts for. That way I hope i am covered!
Seas 27TBFC/G vs 27TDFC/GHide this!Advertise here!
First pics of first build Seas 2-ways. Seas U18RNX/P, Seas 27TBFC/G. Stewart Holmes Multi-Way 24 30th April 2014 11:17 PM
Seas 27TDFC H1189 vs Seas 27TFFC H881 ermes Multi-Way 4 19th April 2011 01:20 PM
WTB: pair of Seas 27TDFC or 27TBFC/G giralfino Swap Meet 1 3rd May 2010 01:39 PM
WTB: Seas 27TDFC , or 27TBFC tweets Renron Swap Meet 0 14th March 2009 10:45 PM
WTB: Seas Tweeters 27TDFC or 27TBFC/G ocool_15 Swap Meet 0 25th May 2008 11:58 PM
