How do I integrate L-Pad components into crossover?
Old 2nd February 2018, 02:58 PM   #11
Rob41 is offline Rob41  United States
Rob41's Avatar
Originally Posted by picowallspeaker View Post
I don't see any convenience in making a PCB for the passive components.
Probably it's meant for industrial application, many pieces.
I don't see either any convenience for putting the crossover inside the box
Again, it's meant for selling the box, all inclusive and user-proof.
Why worry ?
Yes, that's why I'm going that route. It's my first time using passive. I use active in my main systems, but this is for my wife to use so I'm making it plug and play.
en·gi·neer:derived from the Latin ingenium, meaning "cleverness" and ingeniare, meaning "to contrive, devise"
Old 2nd February 2018, 03:31 PM   #12
Rob41's Avatar
Originally Posted by Sonce View Post
That would be logical, if the L-pad is potentiometer (variable R1 and R2, constant R1+R2). Layout from post #3 is OK for fixed values of R1 and R2.
Originally Posted by AllenB View Post
Almost. Take the positive end of R2 from the terminal and attach it to the loose end of R1. Attach the tweeter there.
Okay, I am not using a potentiometer. I am using fixed value resistors. Let me put what I've got in one post here for clarity.
Below are the correct pics of crossover, attenuation and then both combined:
Allen, I finally understand what you're saying. Like in the schematic, R2 has to be placed between + and - terminals after R1. Which would work best?
Thanks for your patience.
Old 2nd February 2018, 10:56 PM   #13
AllenB is offline AllenB  Australia
They are electrically the same. At speaker frequencies, component layout comes down things like vibration resistance and leads breaking, convenience, heat dissipation.
Old 3rd February 2018, 05:54 AM   #14
Rob41's Avatar
Thanks Allen, I appreciate all the help!
-Rob
Old 3rd February 2018, 09:10 PM   #15
Rob41's Avatar
Once I get the crossovers built and refurbish the Sansui SF2 speakers, I'll be using a Carver amp to drive them and this little tidbit I just built.
Old 5th February 2018, 09:17 PM   #16
Rob41's Avatar
Default First crossover completed
The crossover components arrived this afternoon and I was able to assemble my very first passive crossover.
Yesterday I was able to install the new drivers and bring the Sansui SF2 exterior into the 21st century.
One more crossover to go and a bit of mounting work, then I'll be able to hear them for the first time.
Old 8th February 2018, 07:02 PM   #17
Rob41's Avatar
Default Wrapping up
Well, to wrap things up, I got both crossovers done with the attenuation resistors reducing the output of the tweeter by more than 5 db. They sounded awful! The high end was veiled and just seriously lacking.
I removed the resistors for the l-pad portion and it is so much better. Granted, a small reduction in frequencies above 2k would be ideal, I'm using these in my system with a car stereo as the center piece so it's easy enough to use the built in equalizer to reduce the top end a bit.
The SF2's originally had a first order crossover and two 8" mid/bass drivers. Now they have a 2nd order LR with a single up-firing 8" mid/bass driver to integrate with the up firing soft dome tweeter. Both new drivers and the crossovers are a vast improvement over the original configuration. I am very pleased with the outcome.
Thanks for the assist guys and especially Allen.
How do I integrate L-Pad components into crossover?Hide this!Advertise here!
What are the 3 components on my crossover? MikeBP Multi-Way 33 7th January 2017 04:30 PM
2-Way Crossover with 3 Components - What Goes Where? Hwagseonggi Multi-Way 8 23rd October 2015 11:00 PM
Crossover components JC Multi-Way 13 19th October 2003 02:32 PM
Crossover components: what should I use? LKS Multi-Way 2 25th September 2003 01:33 PM
crossover components ray Multi-Way 1 11th September 2001 12:17 PM
