15" 2-way Ideas
15" 2-way Ideas
Old 30th January 2018, 09:21 PM   #1
BobtheBuilderMLG is offline BobtheBuilderMLG  United States
BobtheBuilderMLG's Avatar
Default 15" 2-way Ideas
So my plan is to make a 15" 2-way very dynamic massive speakers. Im new to building so would love any feedback.
Driver I'm think of would be a Beyma SM115/N 15" woofer
http://loudspeakerfreaks.com/Product...roduct_ID=3622
and a Eminence N314T-8 CD
Eminence N314T-8 1.4" Neo Compression Driver 8 Ohm 4-Bolt
with a Eminence H14EA horn
Eminence H14EA 1.4" Cast Aluminum Exponential Horn 60x40 4-Bolt
For the crossover I would add an L-Pad 13 db or so on the CD and using a 3rd order crossover point of 1000 hz. the reason why I chose 1000 hz is because distortion on the CD seems to rise very fast see attached image and at 1000 hz I figured the woofer wouldn't have a real issue with beaming. I also choice a 2-way so that there would be less error in the crossover.
For the enclosure it would be around 6 cubic feet vented and hope to get at-least around 40hz before my 3db drop off. I also want to design the enclosure around the vintage JBL monitor look.
A few questions I have is is am I being realistic with my expectations of these drivers? I also have a mini dsp I use for my dual 21" subs I could use for this project at least for the woofers don't like the idea of using a dsp on the tweeters. I'm not keeping the subs so why not.
Here's a link the an artical on the CD Test Bench: Eminence N314T-8 with H14EA Horn and N320T-8 with H2EA Horn
"The road to Bose is paved with good intentions"
Old 30th January 2018, 09:22 PM   #2
What I want them to look like in a 2-way obviously. Those are JBL 4345
Old 30th January 2018, 09:39 PM   #3
stickinsect is offline stickinsect  United Kingdom
If you want a massive two way google the Blue Thunder loudspeaker.I don't think the wife would like a pair of those in the living room!
Old 30th January 2018, 09:46 PM   #4
A beryllium CD! If only I could afford that. That thing looks awesome.
Old 30th January 2018, 11:03 PM   #5
LineSource is offline LineSource  United States
LineSource's Avatar
The Faital Pro HF146 compression driver(1.4") and LTH142 Tractrix horn are worth your review, as is the Faital 15PR400 woofer. You will find a few threads with crossovers and positive reviews.
----$660--------Focal T-M (1.4" CD + 15")
FaitalPro 15PR400 $260
FaitalPro HF146 1.4" Neo Compression Driver Plastic dome $250
FaitalPRO LTH142 1.4" 60 x 50 Elliptical Tractrix Horn 4-Bolt. $60
custom BW3 - LR4 crossover ~ $100
Old 30th January 2018, 11:15 PM   #6
globalplayer is offline globalplayer  Germany
globalplayer's Avatar
+1 for Faital Pro 15PR400.
Old 30th January 2018, 11:26 PM   #7
Never heard a Faital Pro tbh. I always have preferred titanium though over plastic although that frequency looks much better may have to expand my horizons.
Old 30th January 2018, 11:28 PM   #8
How low does that woofer go and what sensitivity? That box looks small. Never mind the picture didnt load all the way I see it.
Old 30th January 2018, 11:39 PM   #9
LineSource's Avatar
You could build a 3-way (1" CD + 12" midbass + 18" woofer) for the JBL 4345 cabinet using $400 in well reviewed low cost drivers, and ~$160 crossover.
1" DFM-2535R-08 on PRV-WG35-25 = $55
12 Eminence Delta Pro 12A $130
18 Peavey LoRider18 $215
Old 30th January 2018, 11:48 PM   #10
I thought about a 3-way but with a 15" 8" then the CD so I could match the speaker more. I think thats the sizes they used but it just got real expensive for what I wanted. I am also a fan of keeping the crossover frequency away from the 2khz region because of my lack of experience with this making me think a 2 way is safe and less to go wrong. I think the 1khz region would be better for the crossover dip.
15" 2-way IdeasHide this!Advertise here!
First project vintage"Radionette" wolf in sheepsclothing conversion. ideas? flemmz Multi-Way 5 31st January 2017 09:06 PM
Looking for phase plug ideas for horn loaded 10" and 12" drivers Eva Multi-Way 10 11th December 2011 05:17 PM
B200 in a OB with a added "twist". Ideas needed. Mattias S Full Range 4 29th November 2010 06:35 PM
Using a standard pentode-tetrode as output "space-charge tube" any ideas-experiences? bembel Tubes / Valves 12 11th March 2010 05:56 AM
"Power Tracking" in supply, ever heard, DIY ideas? Cradle22 Solid State 19 4th June 2003 09:02 AM
