Old 7th April 2004, 08:42 PM   #1
Send a message via AIM to bhg41088 Send a message via MSN to bhg41088 Send a message via Yahoo to bhg41088
Default Driver Help
I have 2 of the 4.5" Vifa/JBL woofers off of parts express/ I would like to pair these with an inexpensive tweeter for a small monitor for my computer. Can anyone recommend a good, inexpensive tweeter to pair with these? Also, Should i but two more and go with 2 MMT speakers with an overall impedience on 8 ohms, or do a 2 way and have an overall 4ohm impedience?
Old 8th April 2004, 12:44 AM   #2
bump, need help.
Old 8th April 2004, 06:55 PM   #3
Well i decided i would like to do two TMM towers using these. I still need a tweeter suggestion and also, will their be any problems with this that anyone can point out?
Old 8th April 2004, 07:37 PM   #4
http://www.partsexpress.com/pe/showd...number=299-495
If you mean this driver then it has response issues
that make it extremely difficult / impossible to use
for normal 2 way MT or MTM speakers.
http://www.partsexpress.com/pe/showd...number=299-432
http://www.partsexpress.com/pe/showd...number=299-433
If you mean either of these drivers then I could
make some hopefully sensible suggestions.
sreten.
Old 8th April 2004, 10:02 PM   #5
well, it is this first one. Whats wrong with it? and can i still get good sound in a MMT setup?
Old 8th April 2004, 10:54 PM   #6
Well according to the PE response graphs there is strong
step down at 1Khz which is very difficult to correct.
And impedance is 4 ohm per driver.
Bizzarely as it may sound they are best suited to a
TMWW arrangement wired in series for 8 ohm and
with the TM drivers around 85/86dB and the 2 W's
rolled in for BSC, limited bass being OK for HT.
Or a straight TMW, TM the same, but 4 ohms in this
case, with relatively limited power handling re a pair.
sreten.
Old 8th April 2004, 11:05 PM   #7
Well, i was wanting to wire 2 of them in series for an 8 ohm load, then use an 8 ohm tweeter. How hard is this dip to correct?
Old 8th April 2004, 11:47 PM   #8
Hey sreten,
Do you think we could chat for a little while over aim about this? Or anyone else for that matter.
Old 9th April 2004, 12:45 AM   #9
BHG41088 on AIM, i'd really love any help with this, so feel free to IM me.
Old 9th April 2004, 07:21 PM   #10
Well, would 2 of these, used with 2 Dayton 6.5s and a tweeter work in a mtmww setup?
L-pad attenuator for midrange driver 6 1/4 inch driver rhythmdiy Multi-Way 0 4th November 2007 03:32 PM
Base driver to suit ESS Heil driver gerado Planars & Exotics 6 1st August 2007 07:56 PM
FS: Silver Iris Coaxial 15" driver pair (sans XO and compression driver) theAnonymous1 Swap Meet 0 24th April 2007 12:09 AM
Driver/ driver configuration improve soundstage width andy2 Multi-Way 6 16th June 2005 08:47 PM
mtm versus tm driver recommendations on project with $500 driver and xo part limit gsattler Multi-Way 4 20th May 2002 05:54 PM
Page generated in 0.09866 seconds (77.70% PHP - 22.30% MySQL) with 10 queries
